Hot Water Wont Run In Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 08:50 PM   #16
would it help if I posted some kinda picture?
ruthlessbeatle is offline   Reply With Quote
Old 11-11-2012, 05:03 AM   #17
DIY staff
Rewards Points: 7,174
A picture of the shut off valve would get you instructions on safely changing it----
ruthlessbeatle (11-11-2012)
Old 11-11-2012, 11:08 AM   #18
<a href="http://s361.beta.photobucket.com/use...eatle/library/" target="_blank"><img src="http://i361.photobucket.com/albums/o...111_113919.jpg" border="0" alt="Photobucket"/></a>
Old 11-11-2012, 11:09 AM   #19
sorry its the first two picture I just did it on the fly. girls not happy shes working and im on the comp
Old 11-11-2012, 11:36 AM   #20
DIY staff
Need a picture from the side--need to see pipe and method of connection--screw fitting or compression----
Steel pipe or copper-----
Old 11-11-2012, 11:59 AM   #21
<a href="http://s361.beta.photobucket.com/use...eatle/library/" target="_blank"><img src="http://i361.photobucket.com/albums/o...111_124738.jpg" border="0" alt="Uploaded from the Photobucket Android App"/></a>
there I posted a few of it. thanks for sticking it out and helping
Old 11-11-2012, 01:01 PM   #22
Rewards Points: 1,596
Looks like copper supply lines to the shutoff.
If you open the shut off, you get no hot water out of the valve (with the flexible, braided supply line disconnected from it), correct?
Is it possible the handle is turning and the valve stem it is attached to is not? May be a bad valve.
You can take the valve apart and see if there is any junk in the valve seat area (make sure main water valve is off or you'll get wet.).
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
ruthlessbeatle (11-12-2012)
Old 11-11-2012, 01:43 PM   #23
ill give it a shot tomorrow this way if I mess something up I wont mess up a plumbers sunday also. I def think the valve turns. I think this because when I turn it on there is a bit of water in the topand it goes away (assume back into the pipe) but nothing comes out...idk if it helps but I left the flex tube off the valve last night and the pan (spackle tray) had about an inch of water in it. idk if it was a drainage from the flex or from the valve. (it was in the off pos all night)
Old 11-12-2012, 03:51 AM   #24
DIY staff
Sweated copper----and to short of a stub to cut it and use a compression shut off valve----
Copper is good----something has been updated since the house was built----
Do you know how to sweat solder ??? That valve needs to be replaced with a modern 1/4 turn ball valve.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Plumber fixed our h/w problem - now neighbor isn't getting water from one sink? kissiffer4 Plumbing 9 04-01-2011 10:06 PM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
Sink gasping water Filbee Plumbing 7 10-23-2009 10:36 AM
