HOT WATER Won't Light ???? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2011, 09:12 PM   #1
Rewards Points: 150
HOT WATER won't Light ????
My daughter's hot water heater won't light. Well actually it WILL light, but as soon as you let go of the (red button) the pilot light goes out! Have replaced the thermo coupler. It the pilot light lights, I know gas is coming through! Any suggestions? They HW heater is only about 3 - 4 years old?
Thanks!
Evil Scotsman is offline   Reply With Quote
Old 01-23-2011, 09:19 PM   #2
Experienced
Jackofall1's Avatar
How long you holding the "red" button? I does take a minute or so, before you can let it go, if you are waiting long enough, I would be looking at the gas valve next. That is if the thermo couple is generating the millivolt signal needed to open the valve.
The Following User Says Thank You to Jackofall1 For This Useful Post:
Evil Scotsman (01-25-2011)
Old 01-23-2011, 10:02 PM   #3
In a little over my head
Rewards Points: 706
Is the bracket holding the thermocouple close enough to the pilot flame?
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Old 01-24-2011, 07:27 PM   #4
what brand?
some brands have issues with the gas control valve. most common is whirlpool. major recalls with this unit in general.
did the door have screws holding it shut or is it a open burner chamber.
plumbbum0203 is offline   Reply With Quote
The Following User Says Thank You to plumbbum0203 For This Useful Post:
Old 01-25-2011, 09:57 AM   #5
Rewards Points: 150
Had a plumber friend look at it. First he thought the thermo coupler my sil put in might have been bad. Replaced it with one of his, still no go. He said the unit is 5 years old and is discontinued. IF we could find the part it would be about 100 bucks, but then with the age (not sure of the model) we could put that part in and the tank could go next year??? So I will just go buy a new tank and throw it in.
THANK YOU ALL!!!!
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Water heater won't light adfuhrer HVAC 1 12-10-2010 02:59 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
