Old 03-06-2012, 01:21 PM   #1
hot water on top ceiling
can we run hot water on top a ceilling... I m trying to relocate my water heater but now its running hot water underground and by relocating i dont want to break floor to installed new pipes lines...can i do it above ceiling...my home is one floor, and build on 70s'
zapata11 is offline   Reply With Quote
Old 03-06-2012, 01:39 PM   #2
Unless you live in a very warm area that never gets below freezing then I would not suggest it.
Even then with all the weight and the fact that if anything goes wrong it's going to take out anything below the leak it's not a great idea.
Old 03-06-2012, 02:02 PM   #3
Just a DIY guy
I'm about to do that myself. Then again, I live in a warm climate, and our frost spells are brief, and the lines will be foam insulated. I will also put some fiberglass insulation over the lines
Right now I have two separate leaks under my slab, so there appears to be an ongoing problem. I'm not going to chase multiple leaks under the slab.
M3 Pete is offline   Reply With Quote
Old 03-06-2012, 07:46 PM   #4
we have done 100 condo units here inpa ..gets cold...heaters in 1st floor laundry room piping in ceiling hot and cold between duct work insulated...it can work....I would not put heater up there...
ben's plumbing is online now   Reply With Quote
Old 03-06-2012, 07:49 PM   #5
At least use Pex not copper.
Cheaper to run, less likly to bust if it does freeze, less joints to leak.
oh'mike (03-06-2012)
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Water damage to ceiling sheetrock Go4EVA! General Discussion 8 08-29-2009 09:25 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
