Hot Water Temperature In Shower Drops - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2013, 08:21 AM   #1
Hot Water Temperature in Shower Drops
I am trying to diagnose a problem where the hot water from the shower turns lukewarm after 5+ minutes. This occurs throughout the house as well. The hot water temperature drops. Here is what I have performed and/or observed.
-Replaced the Delta Monitor trim shower system. I thought it was the cartridge that mixes the hot/water. This does not fix the problem.
-Flushed the water from the bottom of the water heater to remove sediments
-The cold inlet tube that brings cold water into the water heater is not cold. I have another water heater and the cold inlet tube is cold.
Does anyone have any advice or suggestions?
Please see attached link of my water heater. The one in the middle is the troublesome one. Thanks
https://dl.dropbox.com/u/10499193/heater.jpg
blackscholes is offline   Reply With Quote
Old 01-31-2013, 08:51 AM   #2
Roofmaster
Rewards Points: 2,172
You have three (3) Hot water Heaters???????
Sounds like the dip tube is shot
Old 01-31-2013, 08:55 AM   #3
Yes, one for each unit.
What if the dip tube has broken off?
Old 01-31-2013, 09:18 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 984
That would be your problem, bad lower element / bad or no Dip tube
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
No hot water in shower, but works elsewhere. Please help! neatfreak Plumbing 14 09-18-2012 12:38 PM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 07:47 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Hot/Cold water problem in shower 8thebroker8 Plumbing 8 06-30-2010 07:12 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
