HOT Water Temp Change - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2011, 01:21 PM   #1
Unhappy
HOT water temp change
The shower closer to the hot water heater always gets scalding hot after about 5-10 minutes. I replaced the heater last week and it still does the same thing. Help please as this is dangerous.
inspectordan is offline   Reply With Quote
Old 06-02-2011, 02:02 PM   #2
Turn the thermostat down on the HWT.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
inspectordan (06-03-2011)
Old 06-02-2011, 09:40 PM   #3
Really you think thats it? Something so simple and easy? I hope so as it did the same thing with the old water heater.
Thanks I will give it a try.
Old 06-03-2011, 12:31 AM   #4
The other easy option you can do on the supply line to the shower is install a mixing valve that way you can control the maximum water temp to the shower while letting the rest of the house run hotter water.
That said you may just need to replace the cartridges on your shower would be easier first try and cheaper too. As a general rule for safety sake your hot water tank should be kept above 140f it kills stuff like legionairs in the water.
Adam_M is offline   Reply With Quote
The Following User Says Thank You to Adam_M For This Useful Post:
Old 06-03-2011, 08:49 AM   #5
Rewards Points: 1,528
I would worry about scalding injuries more than risk of getting Legionnaire's disease personally.
From: http://awt.org/IndustryResources/Legionella03.pdf
see pages 12-13 in pdf at link.
bob22 is online now   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Old 06-03-2011, 10:15 AM   #6
Thanks for all the help first off.
So if I keep my heater turned up at least to 140 I can add a mixer and then the temp will stay constant?
Old 06-03-2011, 11:50 AM   #7
Since most of the legionnaires' bacteria can also reside in your aerators, shower heads, etc... in your system, keeping the water at 140 degrees at the heater is not guarantee that they will be killed at these areas as the water will cool down in transit. Further, adding in a mixing valve to cool down 140 degree to 120 degree or lower at the shower head or tub spout would defeat the 140* water. In short, I'd set my heater to 120* and reduce heating costs, risk of scalding. The pdf I referenced said 120* will kill 90% of bacteria in a few hours exposure (a bit slower than the 140* which also is about 90% kill rate) so you aren't losing much.
Old 06-03-2011, 11:57 AM   #8
OK thanks.....But I am still trying to figure out why all the sudden the water gets really hot after using the shower for about five minutes. Have any ideas as to why?
Old 06-03-2011, 12:15 PM   #9
Dan,
How much pipe between heater and shower? It can take a while for all the cold water in the hot water supply piping to exit the shower head before the hot water that follows it comes out the shower head (depending on run of piping, shower head flow rate, ambient temperature, etc).
Run the hot only side of the shower until you think it is not getting hotter with your hand. Measure the temperature. Wait another 5 minutes and measure the temp of the water again. Is it much different?
Old 06-03-2011, 12:26 PM   #10
Thanks Bob:
When I turn it on yes I let it get hot first. The thing is it never happens in the other shower only this one. I would say there is maybe 30-40ft of pipe between the heater and shower and maybe only another 30ft to the other shower. Could it be the hot water valve in the shower heats up after 5 minutes or so then opens up more?
Old 06-03-2011, 12:28 PM   #11
"Could it be the hot water valve in the shower heats up after 5 minutes or so then opens up more?"
Not if you only have the hot valve open.
Old 06-03-2011, 12:32 PM   #12
Well both are open when taking a shower set to warm then it just gets scalding hot after 5 minutes or so....Anyways sounds like the best thing to do is lower the water temp.
Old 06-03-2011, 04:37 PM   #13
"...then it just gets scalding hot after 5 minutes or so"
If the valve is one of those temperature maintaining ones (meant to prevent scalding or freezing during a shower) the mix valve may be messed up. I'm sure a pro can advise on how to fix or google it.
Old 06-03-2011, 05:21 PM   #14
Thanks bob
Tags
hot , plumping , water heaters
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
