Hot Water Tanks For Radiant In-Floor Heating - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2012, 12:33 PM   #1
Hot Water Tanks for Radiant In-Floor Heating
Several pictures of 2 hot water tanks for Radiant In-Floor heating.
They are hooked-up in series right through the concrete wall.
Tank #1 supplies hot water and radiant heat in-floor.
Tank #2 supplies only radiant heat in-floor.
This was configured by a really talented plumber and electrician.
Hot Water Tanks for Radiant In-Floor Heating-hotwater-tank-system-steroids-1.jpg   Hot Water Tanks for Radiant In-Floor Heating-hotwater-tank-system-steroids-2.jpg   Hot Water Tanks for Radiant In-Floor Heating-hotwater-tank-system-steroids-3.jpg   Hot Water Tanks for Radiant In-Floor Heating-hotwater-tank-system-steroids-4.jpg
YupOldBull is offline   Reply With Quote
Old 11-24-2012, 01:05 PM   #2
Rewards Points: 1,512
This will generally work okay provided that the water heater give enough BTU.
Because the radiant heating water and domestic hot water are commingled, it is possible to turn on the faucet and get only lukewarm water if the space heating part of the system just kicked on and the floors were quite cool, pulling down the temperature of the entire "body of water".
Is this considered a "normal" installation? Given all the pipework as shown, how hard would it be to extricate the water heater and replace when it springs a leak? Also the warranty may be voided by this usage.
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
