Hot Water Tank Temp's - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-12-2012, 09:35 AM   #1
Rewards Points: 12
I am trying to determine what the temp settings are on my HWT dial. See image included. What is each bar adjustment 5 or 10 degrees etc. Thanks for any feedback.
Model of Tank: John Wood GSW Superflue
Is the thick red vertical mark right after the work temp 120 Degrees
06Honda is offline   Reply With Quote
Old 10-12-2012, 09:39 AM   #2
Rewards Points: 12,802
Yes the red mark should be 120 deg. One way to find out is try it. 120 is all your need in a home.
Old 10-12-2012, 09:58 AM   #3
Rewards Points: 12
Set it this am up to the thick bar, just curious what the bars were. Thankyou for taking the time to post back.
Paul
Old 10-12-2012, 10:02 AM   #4
Just a guess, 120 divided by 6 = 20.
Old 10-12-2012, 05:22 PM   #5
Rewards Points: 12
Well i picked up a kitchen cooking thermostat and let the water run for a couple of minutes in a sink closest to the hot water tank and it got up to 138 degrees (ouch). Turned it down and will check the new setting tomorrow.
Old 10-12-2012, 05:35 PM   #6
Lots of things can effect the temp. The way your checking it will be fine.
Old 10-12-2012, 06:03 PM   #7
Rewards Points: 12
Thanks Joe.
Old 10-12-2012, 10:33 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 802
Do you have kids in the house? If so...set it down a notch or so.....
Remember, most dishwashers use the heater to heat of the water if it's not hot enough...but you don't want to get the kiddo's too hot....
ddawg16 is online now   Reply With Quote
Old 10-13-2012, 12:20 AM   #9
Missouri Bound's Avatar
Yes, that's the only adjustment you need to make, the dishwasher will have a setting for a high temp wash. My hot water was scorching when I bought my house. When I replaced my water heater I set it at 120 deg. I had to learn to adjust the faucets when I used a lower hot water heater setting but no there is no scalding water from the faucets unexpectedly. And there actually is a difference in my electric bill.
Do you want it your way or the right way?
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
how to stop drops of water at tank top receptacles? young707 Plumbing 6 08-22-2012 06:41 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
