-   -   Hot Water Tank Temp's (http://www.diychatroom.com/f7/hot-water-tank-temps-159825/)
06Honda 10-12-2012 09:35 AM
I am trying to determine what the temp settings are on my HWT dial. See image included. What is each bar adjustment 5 or 10 degrees etc. Thanks for any feedback.
Model of Tank: John Wood GSW Superflue
Is the thick red vertical mark right after the work temp 120 Degrees
http://farm8.staticflickr.com/7162/6...23e811a8e2.jpg
joecaption 10-12-2012 09:39 AM
Yes the red mark should be 120 deg. One way to find out is try it. 120 is all your need in a home.
06Honda 10-12-2012 09:58 AM
Set it this am up to the thick bar, just curious what the bars were. Thankyou for taking the time to post back.
Paul
joecaption 10-12-2012 10:02 AM
Just a guess, 120 divided by 6 = 20.
06Honda 10-12-2012 05:22 PM
Well i picked up a kitchen cooking thermostat and let the water run for a couple of minutes in a sink closest to the hot water tank and it got up to 138 degrees (ouch). Turned it down and will check the new setting tomorrow.
joecaption 10-12-2012 05:35 PM
Lots of things can effect the temp. The way your checking it will be fine.
06Honda 10-12-2012 06:03 PM
Thanks Joe.
ddawg16 10-12-2012 10:33 PM
Do you have kids in the house? If so...set it down a notch or so.....
Remember, most dishwashers use the heater to heat of the water if it's not hot enough...but you don't want to get the kiddo's too hot....
Missouri Bound 10-13-2012 12:20 AM
Yes, that's the only adjustment you need to make, the dishwasher will have a setting for a high temp wash. My hot water was scorching when I bought my house. When I replaced my water heater I set it at 120 deg. I had to learn to adjust the faucets when I used a lower hot water heater setting but no there is no scalding water from the faucets unexpectedly. And there actually is a difference in my electric bill.:thumbsup:
