Hot Water Tank Replacement??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2009, 06:33 PM   #1
Tom
Send a message via AIM to tvlfleming
I currently have a 40 gal. power vent hot water tank that is leaking. I priced a new one and its over $750.00. Can I replace it with a normal vent and run vent pipe out the hole the power vent went threw and go up the outside of the house or does the chimney pipe have to run straight up?
tvlfleming is offline   Reply With Quote
Old 10-13-2009, 07:37 PM   #2
DIY staff
Rewards Points: 7,174
NO. If you do not have a properly installed chimney you must use the power vent.
Old 10-13-2009, 08:36 PM   #3
Tom
House was built in 1975 and didnt have a chimney built in, it must have had an electric hot water tank, then later upgraded by previous home owner. I was told when i bought house it was 2 years old and I've owned 11 years. I thought if I used double wall pipe and went threw basement wall with it and up house it would be alright. Why is it a problem?
Old 10-13-2009, 11:21 PM   #4
Becuase it isn't designed to be done that way and you will create carbon monoxide problems in your home. is the savings of $300-$400 worth putting your family at risk? trust us please. spend the extra money and have it done right. You will be better off for it. and to answer your question as to why.. if the vent pipe cools it will not draw the flu gases out and they will back up into yor home. the power vent blows it out so thats not a problem. double wall runniong outside isn't correct.
plumber Jim is offline   Reply With Quote
Is my Hot Water tank Going K.M.G Plumbing 15 09-02-2009 05:35 PM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 12:48 PM
How much would you charge to plumb a hot water tank? Piedmont Plumbing 12 08-20-2008 11:35 PM
Hot water tank leak Bill46 Plumbing 1 08-20-2008 09:34 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-13-2007 11:16 PM
