Hot Water Tank Question? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2011, 09:26 PM   #1
Rewards Points: 150
hot water tank question?
Hi! I just installed a new hot water tank (with your help, thanks) and I have a couple questions about proper usage. The old tank started leaking around the top blue rim, which I thought was strange. A week before it started leaking, my son had replaced the bottom heating element and had to drain the tank to do so. I'm thinking he may have filled the tank back up too quick with full pressure on the cold water intake and with full pressure and all the air, it was too hard on the inside of the tank which was glass lined. I heard a lot of rattling inside when I removed the old tank. Anyhow I remember when he told me to turn the sink on to get the air out of the lines that it really whomped pretty hard. When I installed the new one I let the tank fill slowly with the cold water valve only about 1/2 on and therefore it didn't build up as much air and when I let the air out of the lines, by turning on the sink, it didn't whomp hard, just hissed. So, now that I have the new one in, I am wondering if you are supposed to have the cold water intake valve all the way on or if you should leave it backed off a little?
guest is offline   Reply With Quote
Old 12-13-2011, 10:04 PM   #2
Rewards Points: 582
open it to the full on position....
Old 12-13-2011, 10:11 PM   #3
Rewards Points: 150
Thanks!
Old 12-13-2011, 10:11 PM   #4
Rewards Points: 582
Welcome....
Old 12-13-2011, 10:21 PM   #5
Rewards Points: 1,440
Originally Posted by guest View Post
The old tank started leaking around the top blue rim, which I thought was strange. A week before it started leaking, my son had replaced the bottom heating element and had to drain the tank to do so. I'm thinking he may have filled the tank back up too quick with full pressure on the cold water intake and with full pressure and all the air, it was too hard on the inside of the tank which was glass lined. ?
The only reason it would have been too hard on the inside of the old tank would be if the tank had almost rusted through and filling it up quick with full pressure was the straw that broke the camel's back.
A new tank can take the full pressure of turning on the shutoff valve fully.
Old 12-13-2011, 10:24 PM   #6
Rewards Points: 150
Thank you so much Alan J. guess I'll keep him
Hot Water Tank Flammable Vapor Sensor Lockout - A.O. Smith - Promax taviyo Plumbing 11 08-14-2013 05:51 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Concrete tank for solar water preheating? Badfish740 Building & Construction 5 03-09-2010 09:20 PM
Is my Hot Water tank Going K.M.G Plumbing 15 09-02-2009 06:35 PM
