Hot Water Tank Placement - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2010, 04:03 AM   #1
hot water tank placement
does anyone know how far from a bathroom door a hot water tank needs to be in order to NOT be affected by this code, or does that even matter?
7.26.1 ..... An enclosure containing the water heater shall not be accessed by a pedestrian door which can be opened from the bathroom or bedroom.
i have a half wall enclosing the furnace and water tank area. the bathroom door is behind this half wall....has always been this way. a recent upgrade to furnace has caused me to now have to comply to this code update, since the tank moved a bit. nice huh?
thank you!!!
baby12121 is offline   Reply With Quote
Old 09-24-2010, 07:17 AM   #2
Although written a bit differently, most codes do not allow a water heater to be in any "living space". I realize that reconfiguring will be a pain, especially since this has been code for many years and someone got by with it. Seems the simplest way would be to make the furnace and water heater area a separate room.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 12:48 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
