Hot Water Tank Leak - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-20-2008, 09:48 PM   #1
Hot water tank leak
A new hot water tank was installed in a new house. The water lines were connected, but the cold water inlet fitting leaked for about 3 weeks. The tank has not yet been used or gas turned on. The fiberglass insulation is now wet (the leak was fixed). Is this tank now ruined since the insulation was wet? Will it eventually dry out without removing the skin?
Thanks,
Bill
Bill46 is offline   Reply With Quote
Old 08-20-2008, 10:34 PM   #2
DIY Junkie!!
Rewards Points: 180
Thanks,
Bill
I'd say give it a while and see if it does dry out. I just replaced a gas-fired tank type heater and started disassembling the unit so that I can use the intact tank for a solar heater. I was impressed by how "stiff" for lack of a better term the insulation is--not at all limp and fluffy like regular fiberglass insulation we install between studs in walls. I'd say it could stand getting wet without sagging and leaving an uninsulated area, give it a try, what have you to lose?????
Doug
YerDugliness is offline   Reply With Quote
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
