Hot Water Tank Flammible Vapour Sensor - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2013, 09:44 AM   #1
Hot water tank flammible vapour sensor
After spraying boots about 7 feet from my hot water tank I had no hot water the next morning. A call to the plumber had someone come and simply unplug the unit and reset it. 4 days later I am without hot water again and request a different plumber. I am now told the whole gas valve needs replaced to the tune of almost $1200. He said the flammible vapour switch would not reset if it was faulty. Is a whole new switch the step I should be taking?
frustrated 2 is offline   Reply With Quote
Old 03-09-2013, 10:23 AM   #2
Roofmaster
Rewards Points: 2,210
Spraying Boots?????????
Yeah, and get your lungs replaced at the same time.
"Use in well ventilated area only"
Old 03-09-2013, 11:01 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 682
They cannot be reset.You can always call the Help# on the tank and verify
Old 03-10-2013, 08:05 PM   #4
Rewards Points: 1,956
Federal law has mandated that HWT have a flammable vapor lock out so when someone cleans his basement floor with gasoline he doesn't get killed. Personally I preffered getting that type of person out of the gene pool.
When this law first came into effect you had only one recourse that was to replace the tank. I suggest you plan to do the same. Newer models have a reset.
The Following User Says Thank You to Ghostmaker For This Useful Post:
old_squid (03-11-2013)
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Tank Sensor A O Smith Promax twins Plumbing 0 05-31-2012 10:02 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
H2OwTo Pressurized Water Tank problems Gary5579 Plumbing 4 12-11-2011 06:25 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
