Hot Water Tank Exhaust Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 07:12 PM   #16
Roofmaster
Rewards Points: 2,210
Sounds like you need a little makeup air. Is your house extremely tight? Fans left on in the bathrooms?
Old 03-25-2013, 07:48 PM   #17
Rewards Points: 44
Is that a power vented water heater? Can you provide the model information?
djlandkpl is offline   Reply With Quote
Old 03-25-2013, 08:51 PM   #18
Rewards Points: 44
Can you also post pics that show more of the water heater and the venting?
Dan
Old 03-25-2013, 09:33 PM   #19
Rewards Points: 6,652
Looks like it could be an older style Rheem Power vent unit http://www.ebay.com/itm/RHEEM-POWER-...p2047675.l2557
The Following User Says Thank You to gregzoll For This Useful Post:
djlandkpl (03-26-2013)
Old 04-05-2013, 10:53 PM   #20
listo's Avatar
Rewards Points: 95
Sorryi haven't gotten back to you guys I hadn't realized there was more replies.
Can't take more pics as I'm away from home, but had a guy come and look at them and he says they're ok, just 13 years old, need a couple things done to them, but he said not really worth it to do it for the age.
listo is offline   Reply With Quote
Old 04-06-2013, 12:51 AM   #21
Rewards Points: 192
What kind of meter were you using? There probably isn't any natural gas there to detect. What you want to check for is carbon monoxide which is colorless and odorless. You can take a smoke pencil near the flu while the heater is on to make sure it is drafting properly.
Rick
bcgfdc3 is offline   Reply With Quote
Water draining into toilet bowl but not from tank black00 Plumbing 6 09-19-2012 08:28 PM
Low water pressure + storage tank pyotrbee Plumbing 1 08-28-2012 07:02 PM
how to stop drops of water at tank top receptacles? young707 Plumbing 6 08-22-2012 05:41 PM
Hot water tank flue has hot exhaust coming out Lynnie59 HVAC 29 08-07-2012 07:37 AM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 09:03 AM
