Old 03-28-2009, 09:28 AM   #1
Default Hot water tank drained - now whole house filter clogs easily
I drained my hot water tank one week ago. Since then, I've had to replace my whole home filter twice due to the filter being clogged. We have well water. I have also noticed the hot water coming out of sinks, etc. sounds like it has air in it.
Any help?
bgalizio is offline   Reply With Quote
Old 03-28-2009, 10:56 AM   #2
011000100110111101101111
DangerMouse's Avatar
open all faucets to remove air, then turn them off.
keep changing filter until it stays clean. you likely stirred up some gunk it needs to clear out.
DM
Magical, Musical, Mysterious FUN!
http://www.youtube.com/user/MickeySoume
Now Featuring: Mickey's Multi-Talented Mutts!
DangerMouse is online now   Reply With Quote
Old 03-28-2009, 11:25 AM   #3
I don't know why draining the water heater would cause this, unless you drained it and then refiiled it without flushing out the deposits from the bottom of the tank. By not flushing before refilling the tank, you just broke up the existing scale and allowed it to enter your hot water piping. This should not have clogged the cold water lines or whole house filter though, only the hot water piping.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 03-28-2009, 11:32 AM   #4
Master Plumber/Mechanical
Any help?
Are you getting hot water out of the cold side?
If you are look at the pressure gauge and see what the pressure is. Depending on the pressure switch you have..most common 30-50 of 40-60 switch you should have a reading of either 40 or 50 psi. Most wells are set up with the 30-50. Where the pump turn on at 30psi "Cut in" and turns off at 50psi "Cut out"
If you get hot/warm water out of the cold you could have the stages in the well pump out where the system is not building up pressure like it should. Making the pump run and warming the water around the pump and being pumped out when you turn on the water but noticing it on the cold side more than the hot side.
Have you noticed a higher electric bill?
I'm just taking a stab at this because I don't fully understand your post " I have also noticed the hot water coming out of sinks, etc. sounds like it has air in it."
Old 03-28-2009, 01:12 PM   #5
wannabe
This doean't make sense . Usually whole house filter is installed b-4 the w.h. I don't see how draining w.h. has anything to do with clogged filter.. The trash / gunk must be comming from the well
kenmac is offline   Reply With Quote
Old 03-30-2009, 07:11 PM   #6
Our whole house filter is before the well. It seems all too coincidental that I am having to replace the filter every three days or so since I drained the hot water tank, though.
It seems like our hot water is lower pressure than the cold. The hot water also has had some particulates in it when we first turn on a faucet. The "air" issue was solved by running the hot faucets for a short time. No pressure gauge around the water filter. The cold water comes out cold and the hot comes out hot.
Any other information I can provide?
Old 03-31-2009, 09:31 AM   #7
Update: it looks like the whole house filter is being clogged by rust in the water. We used to get 3 weeks or so on a filter, now it's 3 days. Not sure why it's clogging earlier after flushing the water heater, as the filter is before the heater.
The previous owners installed the water softener after the filter. So, it's the well > pressure tank > filter > softener. Should we change the order of anything to help the iron problem?
Old 03-31-2009, 10:00 AM   #8
glad that worked... try this now, remove filter, open the bathtub faucet (and others) and run full blast for 10 minutes or so (you want the pump to kick in after drawing out the pressure tank) to try to bring out as much rust as possible. clean and replace filter, run water again for a few, and then check rust collecting on filter once more. it should be gone, or at least way less.
DM
Old 03-31-2009, 10:09 AM   #9
oops, remove the screens from the faucets first to allow more flow.
DM
Old 03-31-2009, 11:10 AM   #10
When refilling the hot water tank you may have stirred up sediment in the pipes upstream, for example between the well and the pump.
Bait gone and the mouse trap has not snapped? Maybe ants got there first.
Old 03-31-2009, 10:10 PM   #11
Idiot Emeritus
I would agree with AllanJ here. Re-filling the hot water tank is the first time in quite a while that there has been high flow for a long time in the well to tank line.
If you do as DM says, it'll likely get most of the loose stuff out of the lines. Do this only on the cold lines, you don't want the loose particles in the hot water tank.
You might be surprised at how icky the water is at first.
Rob
micromind is offline   Reply With Quote
Old 04-01-2009, 08:37 AM   #12
thanks rob, i forgot to mention that.
DM
Old 04-01-2009, 09:07 AM   #13
Last night I flushed the pressure tank, allowing the pump to run for 10+ minutes straight. Changed the filter too. Hopefully that will help.
Thanks for all the help thus far. This is a great forum.
Old 04-01-2009, 10:14 AM   #14
good job. keep us posted!
DM
Old 04-04-2009, 04:40 PM   #15
Filter is clogged again. Time to call a well guy...
More On This Topic
So, we see from back there that the pipe that comes from the water tank, from the rainwater tank, comes in here and then goes into this little pump. And this little pump has a pressure tank in here so that the pressure is always there. Because what we... Read More »
Hi this is Francisco Cales from Tampa, Florida with Pool Inspectors on behalf of Expert Village and our basic theme for today is pool maintenance. When cleaning your filter the first thing to check is to see if you filter needs to be cleaned. The first... Read More »
Jacuzzi Filter Maintenance
Jacuzzi Filter Maintenance by Expert Village
Hi this is Francisco Cales from Tampa, Florida with Pool Inspectors on behalf of Expert Village. Our theme for today is basic spa maintenance. When cleaning your filter, the first thing to check is whether the filter needs cleaned. Find out what the... Read More »
Welcome to the Gundel Winery. I am here on behalf of Expert Village. I am Joel Carmen, representing Gundel Winery since nineteen ninety-eight. So you put the wine, you put this agent into the barrel. Of course you will have to mix it. And then you will... Read More »
You can easily install a water filter under your sink to clean the water before it leaves a special water faucet. These under sink water filters check for a large variety of harmful contaminates found in tap water, making the under sink water filters... Read More »
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 05:01 PM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 01:09 PM
Solar hot water + tankless gp_wa Plumbing 3 08-27-2008 02:48 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 01:16 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 01:05 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
