Hot Water Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2011, 02:46 AM   #1
Post
Hot water tank
How come I very little hot water preasure?
margie1021 is offline   Reply With Quote
Old 08-23-2011, 02:56 AM   #2
Post
Hot Water Tank
I just moved into a single wide trailer I have a problem with my hot water tank there is very little hot water preasure. I have pleanty of hot water so I dont understand why there is no hot water preasure. I have cold water preasure but no hot water preasure. When I turn the water on I here air preasure in the lines. Please help cant figure it out not sure if I can do anything myself befoe I have to call a plumber and spend alot of money to fix my problem.
Old 08-23-2011, 06:04 AM   #3
DIY staff
Rewards Points: 7,174
If the pressure is low at the bath tub---you should check and see if the shutoff valve above the water heater is fully open.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Can I use existing hot water tank for radiant floor? Red Squirrel HVAC 4 12-14-2010 06:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
