Hot Water Surging - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2011, 03:33 PM   #1
hot water surging
My hot water surges kitchen single lever faucet that is closest to the water htr. The surging occurs as the water gets hotter. I have disassembled faucet mechanism but found no debris. ( Note this is in a seasonal home and I am suspecting some sort of debris in line.) There is no surging at any other outlet and it is only on the hot water
Bill Rulli is offline   Reply With Quote
Old 04-28-2011, 03:37 PM   #2
Does it have a shutoff valve under the sink? that would be my next suspect.
broox is offline   Reply With Quote
Old 04-28-2011, 04:20 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
Is there absolutely no sign of surging in the hot water faucets for your bathroom basins, bathtub spout or shower head?
HRG
Homerepairguy is offline   Reply With Quote
Old 04-28-2011, 06:24 PM   #4
water surging
There is no shut off valve. The hot water "pulsates" 4-5 x /sec as it gets hotter. almost like a water hammer. Could there be an air pocket? Debris in line??
Old 04-28-2011, 06:38 PM   #5
If it was me, I might try a couple of things:
1.Install shutoff valves under the sink, so I could attach a supply line and spray water into a bucket, kind of bypassing the faucet.
2.Swap the supply lines on the faucet so hot and cold are reversed and see what it does.
3.Take the guts out of the faucet and turn the water on and see if anything (debris) comes out.
Good luck!
Old 04-28-2011, 07:22 PM   #6
No shut off valve undersink. No other pulsating anywhere else in system.??
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
