Hot Water Supply Pipe Route Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-31-2012, 09:39 AM   #1
Rewards Points: 131
hot water supply pipe route question
other than shut off All valves(hot and cold), and then drain. do i need to shut off or turn down the water heater when install new hot water pipes?
s002wjh is offline   Reply With Quote
Old 01-31-2012, 10:04 AM   #2
Rewards Points: 13,250
No, as long as the incoming water is shut off to the water heater.
Old 01-31-2012, 10:06 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If you're draining the water heater (as it looks like you are) then YES, TURN OFF THE POWER.
Journeyman Plumber
Old 02-01-2012, 03:44 PM   #4
Rewards Points: 131
i'm not draining the water heater. i need put a Tee in a hot water pipe down the line for a sink. so i like to know i should turn the heater off because once i shut off all the valve(both hot/cold valve from/to the heater) then would the heater continue heat the fix amount of water in the tank therefore create alot pressure ?? or heater will basically stop once the temperture in the heater reach certain degree? if its the latter case then i don't think i have to turn off the heater.
Old 02-01-2012, 11:32 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If youre not draining the heater id just shut the cold water supply valve off going to the heater.
Turn the gas valve to pilot
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water in Basement. One last Question. daltinator Building & Construction 8 01-26-2012 12:59 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
