Hot Water Supply Cuts Off In One Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-22-2010, 10:36 AM   #1
I have a remodeled row house. I have one bathroom sink on the second floor that is behaving oddly. When you turn on the hot water only (this doesn't happen with the cold water on or in combination of hot/cold on), the water will run for a second and then very abruptly stop. There's a slight noise when it happens, like it's a pressure thing. If you turn the knob off, you'll hear the noise again, and then you can turn it back on. Sometimes, if you only turn it on slightly it will work, but when you turn the faucet on higher, it happens again.
Any ideas?
swilschutz is offline   Reply With Quote
Old 02-22-2010, 06:08 PM   #2
What brand faucet is it? is it a single handle or 2 handle? I will guess it's a 2 handle and suggest you check the hot stem.
plumber Jim is offline   Reply With Quote
Old 02-22-2010, 06:23 PM   #3
if it is a two handle faucet the stem is broke
khull is offline   Reply With Quote
dishwasher water supply line options kenm09 Plumbing 2 02-11-2010 08:17 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
