Hot Water Stopped Running, Need New Ater Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2010, 06:10 PM   #1
hot water stopped running, need new ater heater?
I bought a house, initially I turned on the water and power and the water heater seemed to work, came out of all faucets in house, then a few weeks later it stopped running when you open a hot water faucet. I then noticed a little bit of water below and around the bottom of the heater cant find where the leak is coming from.
Possible causes? should I just get a new hot water heater?
gfunk08 is offline   Reply With Quote
Old 10-08-2010, 07:20 PM   #2
Rewards Points: 1,532
Some causes of opening a hot faucet and nothing comes out:
THe valve at the cold inlet to the water heater was turned off or sediment from the main water supply clogged it.
The pipes have lime deposits after decades of use, reducing the diameter of open space through which water can flow and some sediment finished clogging the opening.
So much sediment has accumulated in the bottom of the water heater tank that it blocks the cold water from entering via the dip tube.
The tank having rusted out and sprung a leak is probably not the cause of no hot water at all coming out of the faucets.
Old 10-09-2010, 08:11 AM   #3
Thanks Allan for the reply, it sounds like it could be the sediment clogging something, the house was built in 1954.
A couple other points, the water heater is from 2006, the house was vacant for almost a year before I purchased it.
Might there be an easy solution or would you suggest a plumber?
Old 10-09-2010, 09:18 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 774
Is this a gas heater? The water you see may be condensation. 4 yrs is a pretty short life span.
As far as no hot water flow, check inside the hw nipple at the top of the tank. There is usually a rubber assembly inside it. Or perhaps a ball check. Make sure that is not pluged with sediment.
Tankless Water Heater welshie Plumbing 12 03-03-2010 12:46 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
