Hot Water Stinks - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2014, 07:17 PM   #1
Rewards Points: 82
Hot water stinks
My company sold an electric water heater to a customer and 2 weeks after it was installed, they called us in as the anode rod had caused the water to smell. We replaced the anode with an upgrade from the manufacturer as to keep the warrenty valid, but 2 weeks later, they called again with the water smelling bad again. When I replace an anode, i drain the heater after cooling the tank with a flush, then add a gallon of bleach while refilling and chlorinate the hot water lines throughout the building to kill any remaining bacteria. This is the first time the upgraded rod has failed to solve the problem in my experience. Now the manufacturer is staing voltage spikes or lulls may be responsible for the rod failing. Has anyone experienced this and if so, what is the science/ explanation as to how voltage affects the rod?
karin els is offline   Reply With Quote
Old 10-27-2014, 07:41 PM   #2
Retired Army Veteran
jmon's Avatar
Rewards Points: 1,352
Hot water stinks
Are we talking well water here or domestic water from a city municipality? Also is there a water softener involved here? Electric or gas hwh? Thanks.
jmon is online now   Reply With Quote
Old 10-27-2014, 07:56 PM   #3
jmon's Avatar
Hot water stinks
Originally Posted by karin els View Post
Now the manufacturer is stating voltage spikes or lulls may be responsible for the rod failing. Has anyone experienced this and if so, what is the science/ explanation as to how voltage affects the rod?
I suppose it's possible for a stray voltage, loose neutral, or ground to prematurely cause anode rod failure. Idk. However, it seems there would be other electrical issues wrong with the house as well. Have an electrician rule out any bad wiring/breakers, shorts, etc. as a cause. Just a suggestion.
I can't explain the science or theory behind it, others will be along with more advice/suggestions. Thanks.
The Following User Says Thank You to jmon For This Useful Post:
karin els (10-27-2014)
Old 10-27-2014, 10:04 PM   #4
Rewards Points: 82
Hot water stinks
The customer has a well, with a softener, and as my original post said, it is an electric hwh.
Old 10-27-2014, 10:06 PM   #5
Rewards Points: 82
Hot water stinks
jmon, I have the electric service provider putting their device on the customers meter to record all of the electric variences. They were more than happy to offer to help, and I am looking forward to seeing what they find here in the next couple of days.
The Following User Says Thank You to karin els For This Useful Post:
jmon (10-27-2014)
Old 10-28-2014, 06:57 PM   #6
Rewards Points: 1,688
Hot water stinks
Perhaps install a powered anode this time.
http://www.waterheaterrescue.com/pag...wer-Anode.html
Ghostmaker is online now   Reply With Quote
The Following User Says Thank You to Ghostmaker For This Useful Post:
karin els (10-28-2014)
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 02:56 AM
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
