Hot Water Sputtering Throughout The House - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2010, 08:24 AM   #1
Remodeler
adpanko's Avatar
Rewards Points: 150
Hot water sputtering throughout the house
All of the hot water in our house sputters for a few seconds when we first turn it on. All faucets and showers have this problem. The water will sputter and spit a little air for a few seconds, then it stops. It seems as if air is getting in the lines. It will happen every couple of hours; seems like air is building up, then released when we use the hot water, then builds up again.
We had a new hot water heater put in over the summer. Prior to that being installed, I don't believe we had a problem with the hot water. But it seems to be getting worse, especially over the last few weeks. Anyone know what it could be? I doubt it is coincidental that the problem started when the new hot water heater was put in. I had the plumber come and check it out, and he said it seemed strange, but didn't know what it could be.
adpanko is offline   Reply With Quote
Old 01-17-2010, 09:00 AM   #2
If this has been going on since getting the new water heater put in, I'd go with that theory. I'd either try getting the one who installed it back to check it out or go with another plumber. There should be some type of warranty on this, so before voiding that, I'd make some calls first.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 01-17-2010, 09:51 AM   #3
Civil Engineer
Rewards Points: 4,514
Sounds like air is getting into your lines, and from the sounds of it just the hot water. I have a similar issue on the cold water side of my system, but not nearly as severe as the problem you describe. I have checked my system out, and I have not found any obvious leaks. I am on a well, and I suppose there is a possibility that air is entering via the well, however I have not heard a good explanation of this issue. Perhaps someone can enlighten us as to how air gets into a line without a leak?
Old 01-17-2010, 10:02 AM   #4
Was on well water at our last house, sometimes it was the aerator on the faucets getting some grit in them, will give the same effect as air in the line. Those water savers have some tiny holes in them.
LIVING THE DREAM
Old 01-17-2010, 11:36 AM   #5
Air in the lines!
Air coming out of the hot and cold faucets is caused by air getting into the system from somewhere! Air is usually more prevalent on the hot water side because it settles to the top of the hot water tank and comes out first when the hot water is turned on.
Air getting in the lines on a well system can be caused by a low water yield; the pump being installed to near the pumping level; a well being pumped beyond it's makeup capacity and in some instances from cascading water entering the well above the pump. These can all be rectified however each situation must be diagnosed seperately.
Porky Cutter, MGWC
Master Ground Water Certified
www.dci-inc.us
Porky is offline   Reply With Quote
Old 01-18-2010, 04:13 PM   #6
Remodeler
adpanko's Avatar
Rewards Points: 150
Thanks for the replies. It seems clear that air is somehow getting into the lines. And in my case, just the hot water. But where could air possibly be getting in. Wouldn't that require there be a leak somewhere? If that were the case, I would notice it. Is it possible that there is some kind of organic reaction going on inside the take that is producing gas/air? Maybe some sort of mineral or something in our water that is interacting with some surface on the inside of this particular water heater but not the old one?
Old 01-18-2010, 05:36 PM   #7
You on city or well? Could be the Jersey Devil.
SULTINI is offline   Reply With Quote
Old 01-18-2010, 05:38 PM   #8
would an expansion tank at water heater help?
Old 01-20-2010, 09:02 AM   #9
No, an expansion tank will do nothing here!
Sometimes methane gas or sulphur gas can be in the water and show up as air in the faucets, however the user would usually recognize an odor. If it was community or city water, the neighbors would be complaining of the same problem as well.
Porky, MGWC
www.dci-inc.us
Old 01-21-2010, 09:55 AM   #10
I would go with an expansion tank first if there was no other answers.
Possible to install a air vent on the hot water system.
If the cold is OK it has to be HWH issue.
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Old house with water troubles wade Plumbing 1 01-16-2008 09:24 AM
