Hot Water Smells Like Sulfur. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2012, 10:53 PM   #1
Hot water smells like sulfur.
Our hot water smells like sulfur, but the cold side is fine. What could cause this problem?
tyhorstman is offline   Reply With Quote
Old 01-29-2012, 10:57 PM   #2
Rewards Points: 14,020
Anode rod needs to be changed in the water heater.
Old 01-29-2012, 11:02 PM   #3
That's what we thought, but the water heater is only 4 months old.
Old 01-29-2012, 11:07 PM   #4
Actually we changed the water heater because the water smelled like sulfur, and the new one was fine for about two weeks, after it started stinking we turned the temp up to about 140 degrees and it didn't change anything.
Old 01-29-2012, 11:11 PM   #5
http://www.howtodothings.com/home-ga...-water-heaters
Also get your water tested.
Old 01-29-2012, 11:16 PM   #6
Ok thanks
Old 01-29-2012, 11:29 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
City water,well water?
If youre on city water do your neighbors have same problem?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-29-2012, 11:38 PM   #8
I'm on city water and the neighbor's water is fine.
Old 01-29-2012, 11:48 PM   #9
plummen's Avatar
Galvanized water piping?
Old 01-30-2012, 12:24 AM   #10
Is there an unused hot water line somewhere which may have filled with air?
Like a bathroom where the faucets are not used?
Laundry?
Etc.
If yes, run the water in those lines to get the air out and flush them.
Billy_Bob is offline   Reply With Quote
Old 01-30-2012, 08:27 AM   #11
Rewards Points: 1,538
Magnesium water heater anode rods tend to cause more odors in the hot water but they do a better job of retarding tank corrosion compared with the alternative of aluminum rods.
AllanJ is online now   Reply With Quote
Old 01-30-2012, 11:32 AM   #12
No everything is PVC that I'm aware of. Why?
Laundry?
Etc.
Yes there's a bathroom that we don't use, and we flushed it today but why would that make the other lines stink?
Old 01-30-2012, 12:34 PM   #13
I don't know???
But I do know of another case where there was a pipe for future use going up to a dead end. There was rotten egg stink in the hot water lines and air in that pipe.
We opened the cap to fill it with water and flush it, then end of smell problem.
And air can get into regular water lines when the water is turned off. So each time water turned off, flush all lines.
Old 01-30-2012, 12:55 PM   #14
removed
Hardway is offline   Reply With Quote
Old 01-30-2012, 06:32 PM   #15
Originally Posted by Hardway
140 won’t do it, it needs to be 160 or above to kill or destroy the sulfur bacteria. Then flush the tank and hot water lines to remove the dead bacteria. Use a cooking thermometer to check hot water at closest faucet.
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Ok I'll turn it up, I'll also check the anode too.
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 02:47 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
