Old 06-05-2010, 11:26 AM   #1
Hot water smells like rotten eggs
How do I get rid of the stinky rotten egg small from from my hot water? Do I have to flush out out my water heater? If so, how do I do it?. We bought our home through a builder 7 1/2 years ago and just realized we do not have a owners manual for our water heater. Can you steer to the right resource? Hopefully this is something a layman can do. --Greg
GPBurke is offline   Reply With Quote
Old 06-05-2010, 12:08 PM   #2
Handyman
I was just listening to a handyman show on the radio and someone called in with that very problem not 10 minutes ago. The answer (apparently) is to change the anode in the water heater. It is made of magnesium and is used to control the calcium buildup. When it breaks down it smells like rotten eggs.
canadaclub is offline   Reply With Quote
Old 06-05-2010, 10:11 PM   #3
Do you have a well or city water?
Old 06-05-2010, 11:37 PM   #4
I agree!!!
It happens with well water around my area frequently.
Mr. Green is offline   Reply With Quote
Old 06-06-2010, 08:56 AM   #5
The magnesium anode rod is replaced with an aluminum one.
The purpose of the anode is to retard the rusting out of the tank. The lesser? of evils is that the aluminum rod doesn't retard the rusting as much.
The anode rod must make electrical contact in the form of good metal to metal contact with the tank (at its screw threads) so you need to go easy on the Teflon tape or pipe dope.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
Old 06-07-2010, 08:40 AM   #6
After you replace the anode rod, you want to disinfect and flush the water heater of the odor causing bacteria, then after its flushed, refill the heater and turn the temp up all the way to 160 degrees or higher for several hours, then flush the heater again, and you should be all set.
The Engineer is offline   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 07:48 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Washer drain smells like eggs Sarah24 Plumbing 4 12-04-2008 06:21 PM
Water Mystery - Sump Pump Set Right? robertr4836 General Discussion 4 02-13-2008 03:32 PM
