Hot Water Shuts Off In Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2013, 09:01 PM   #1
Location: mid-Michigan, halfway between Flint and Lansing
hot water shuts off in shower
I'm not a plumber by any means,and this is a problem (really more of an annoyance) that has me stumped.
My house has a single full bathroom. The hot water works fine in the entire house, including the shower, but if the shower is turned all the way to hot, almost all water flow stops after approximately a minute. The shower has a single handle mixing valve, and if the handle is turned even very slightly away from full hot, then full water flow returns immediately. The water temp is fine, still hot. It only happens in the shower, all sinks act normally. I have not tried the tub faucet to see if it happens there as well.
I'm assuming its a problem with the mixing valve, which will be replaced this summer when we do some remodeling and make that bathroom larger. I'd like to make sure it is not some other possible problem that I could resolve during the remodeling, which would be costly to try to repair after remodeling is finished.
Any tips would be helpful and appreciated.
Bill
Smithingell is offline   Reply With Quote
Old 03-29-2013, 09:04 PM   #2
Rewards Points: 2,108
Sounds like a cartridge issue in your faucet.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Smithingell (03-29-2013)
Old 03-29-2013, 09:58 PM   #3
Thats what I am assuming. If so, it will be resolved with the remodel, so no point in bothering with it in the meantime. I am just concerned there may be something else that may cause it, and don't want to have to remove new walls or something like that to fix it afterwards.
Old 03-30-2013, 09:40 AM   #4
Plumber & Gasfitter
Rewards Points: 77
Would it not make sense then to simply replace the cartridge now? Then if you were still having problems you could address them in the reno?
joeplumber85 is offline   Reply With Quote
Old 03-30-2013, 10:02 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Definitely sounds like a cartridge or burn safety issue.
No hot water in shower, but works elsewhere. Please help! neatfreak Plumbing 14 09-18-2012 11:38 AM
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 06:47 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 05:36 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
