Hot Water To Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 11:51 PM   #1
Exclamation
Hot water to shower
I'm having an issue with the hot water in the shower. We've been in the house a few months now and the hot water in the shower isn't hot like it was when we first moved in and it becomes colder much much faster. All of the faucets in the house still get very hot and have no trouble staying hot so I think it would just be something to do with the shower. Any suggestions?? Thanks!
tylerdj is offline   Reply With Quote
Old 10-15-2011, 07:24 PM   #2
Rewards Points: 516
See if you can find instruction sheets for installation of the brand you have. Once the handle and finish piece around the valve (2 screws?) are removed, there are adjustments on the inner valve to balance hot and cold levels. And limit devices to restrict hot water temp.
Suspect young children were previously in the house.
diyorpay is offline   Reply With Quote
Old 10-15-2011, 07:55 PM   #3
If you had good hot water earlier, and now it's less so, then it could be that your shower cartridge needs to be replaced.
VIPlumber is offline   Reply With Quote
Old 10-15-2011, 09:49 PM   #4
Msradell's Avatar
Rewards Points: 348
Becoming colder much faster is quite often a sign of a burned out element in an electric of water heater.
Msradell is online now   Reply With Quote
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Shower only has hot water sixx Plumbing 2 03-12-2011 08:05 AM
Potential Water Issue in New Shower? cobrakai Kitchen & Bath Remodeling 4 02-12-2011 05:36 PM
I have lost water pressure in my shower kiddd66 Plumbing 6 10-15-2010 07:34 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
