Hot Water Recirculators - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-28-2008, 03:52 PM   #1
Hot water recirculators
I am planning to install a recirc unit to save water. I am leaning toward the Watts 500800 mostly because it is outside in the garage and I won' have to listen to the pump motor. Are there better units ? What is the downside of this unit? I have read that the hot side dumps into the cold side and heats the cold water. Is that True? Is that bad? What other questions should I ask? Also, Isee the units on Amazon For bargain prices. Any Comments?
thanks
George
George1 is offline   Reply With Quote
Old 12-28-2008, 08:28 PM   #2
Rewards Points: 12
I am looked at the watts system and the grundfos comfort system. They are the same with the only difference is the color of the pump. They both use the thermostatic crossover valve which gets installed at the farthest faucet on the hot water line. Those crossover valves close once 95 degree water contacts the valve to prevent hot water from entering in to your cold water line. This being true, it also means that anytime less than 95 degree water "is not" contacting the valve, then the valve is "OPEN". Connecting your hot and cold water lines with a normally open valve has it's problems. If the valve is open and you use cold water, water siphons out of the hot water line into the cold water line until the valve closes. This happens because of pressure differences between the hot and cold lines during cold water use. Flushing your toilet, with this valve installed can now fire up your water heater due to siphoning through the open valve. One site explains it more clearly than I ever could. Check out http://www.redytemp.com/hot-water-circulators.htm.
DIY4WIFE is offline   Reply With Quote
Old 12-28-2008, 10:05 PM   #3
Electrician
I use the Watts system, I actually turned the circ pump off and just let it gravity recirc, otherwise I end up with very hot water on my cold side and it can take a minute or to to cool off.
chris75 is offline   Reply With Quote
Tags
hot water circulation , hot water circulators
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
