#1 |
Hot water recirculating system
I recently have repiped our whole house using a professional plumber. The hot water recirclating loop is working perfect as long as the pump is running. When the pump is not working for a while we can only get the water temp up to a "luke warm". When I turn the pump back on----- it is almost instantly hot. Very wierd and I nor the plumber can figure this out. Help ???
#2 |
Doing it myself
Isn't that the way it's supposed to work?
![]() I'm confused at why you need a pump in the system, if you're intending to turn the pump off and have instant hot water everywhere.
Journeyman Plumber |
#3 |
Master Plumber
Your getting a mix did he install a check valve in the system. or its piped in wrong.
Experience is Knowing what to do next, Skill is knowing how to do it To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
call me E
I second the mix. got a picture of the pump piping?
When posting in forums, letting us know your location will help others give better feedback/advice/solutions to your questions |
| The Following User Says Thank You to TheEplumber For This Useful Post: | Greg Wright (09-01-2012) |
#5 |
like Javiles said you are getting a mix. with the pump off it is pulling water through the recirculating line most likely. if there is no check valve have your plumber install a spring check not a swing check.
| The Following User Says Thank You to DannyT For This Useful Post: | Greg Wright (09-01-2012) |
#6 |
Doing it myself
Ah these beers got me reading half of a post and then making a decision. Good thing I don't drink on the job!
![]() ![]() I would also agree that you are getting some sort of crossover. A picture(s) of how the water heater is plumbed would help immensely.
| The Following User Says Thank You to Alan For This Useful Post: | Greg Wright (09-01-2012) |
#7 |
I will post a picture soon. First time user and I don't know exactly how to get a picture up. Soon......
#8 | |
call me E
Hot water recirculating systemQuote:
#9 |
call me E
Better then a picture-- have your plumber join us here.
#10 |
still working on the photo. I really want to figure this out. I looked at my set up and the plumber as routed the return loop horizontally through the cold water feed on the top of the tank. thr is a check valve on the cold line but no check valve on the hot return. I think that thr should be because when the pump is not pulling----I think that then the hot water is getting partially pulled back through the hot return.
#11 |
The picture of my plumbing is attached below the yellow valve with pump and timer is the hot water loop feeding back into my cold water at the top of the tank
#12 |
Doing it myself
Looks like too many pipes to me.
Please elaborate : the 1/2" line in the back going vertically with the paint on it : What does that go to? Also : Where is the flex line in the foreground going? W/H inlet? Nevermind all that ... he's missing a check valve on the outlet of the pump. Tell him I want a cut......
Journeyman Plumber Last edited by Alan; 09-01-2012 at 11:55 PM. |
#13 | |
call me E
#14 |
the flex line in the foreground is the electrical conduit running from the box to the tank. The 1/2 recirc line with the yellow shut off valve handle needs a spring valve installed after the pump. It makes sense. Not sure why my plumber didn't get that. He certainly has had lots of experience. Thanks for your help.
greg |
#15 | |
call me E
In the mean time, you can close the yellow valve to stop the back feed-turn the pump off too.
| Display Modes | |
| Grossly insufficient water supply to toilet wasting water? | mysterylectric | Plumbing | 8 | 01-17-2012 12:19 PM |
| Testing 12 year old hot water expansion tank? | DJfixer | Plumbing | 2 | 01-01-2009 09:09 AM |
| boiler / Over-pressurizing | cparke | HVAC | 1 | 05-21-2008 06:54 AM |
| hot water recirculating/sediment confusing problem | rcatty | Plumbing | 1 | 01-06-2008 04:51 PM |
| Hot Water Recirculating Line | jdupre | Plumbing | 9 | 01-06-2008 08:49 AM |
