Old 01-06-2008, 11:03 AM   #1
Default hot water recirculating/sediment confusing problem
I have been in this house for 10 years. I am on a well, and have two hot water tanks set up to work in parallel. I am getting a sediment discharge in my hot water, only from my upstairs faucets and showers. The hot water tanks were extremly dirty and it took several drainings and flushings to clear most of the debris. Apparently, I have a recirculating system, as I notice copper pipes entering the drain valves at the bottom of the tank. I see no pumps anywhere on the system, nor have I heard anything "pumping" since I have been in this house. The recirculating pipes branch off in two opposite directions to either side of the house. The recirculating system seems to work fairly well on one side of the house (although lately nowhere as good as in the past). I see no positive results on the other side of the house, where I traced that circulating line. Indeed that side of the house, be it upstairs or downstairs, never showed any benefits of instant hot water.
The recirculating lines are very hot for about 10-15 feet as they join the bottom of the hot water tanks. I see no check valve anywhere. I suspect I am getting backflow up the recirculating pipes with hot water off the bottom of the tanks. Is it possible that sediment off the bottom of the tank could be pushed up to my second floor faucets via the recirculating lines causing the sediment discharge? The upstairs faucets in the master bathroom with the fastest hot water, discharge the most debris. However, in a second upstairs bathroom there is discharge from one sink faucet and the bathtub faucet (the instant hot water, if installed in both faucets works poorly, if at all). Interestingly, I see no discharge from the second sink faucet in that bathroom. A third bathroom upstairs discharges in a similar fashion to this latter bathroom, but the instant hot water appears to work (this is on the same side of the house as the master bathroom, and must feed off the same branch of that end of the recirculator. The other bathroom, that works poorly, if at all, is at the far end of the house and has a long (25-50 foot) horizontal run to the water heater. I don't see how that could work properly on a gravity based system ? In summary, how do I stop this sediment discharge, and secondarily, how do I fix my recirculating system on the other side of the house? Thank you
rcatty is offline   Reply With Quote
Old 01-06-2008, 05:51 PM   #2
The recirculating lines should have check valves. Opening a faucet should not draw hot water from the bottom of the tank. These systems usually work off natural convection and need no pump.
LawnGuyLandSparky is offline   Reply With Quote
More On This Topic
A tank like this cost you about $1,500 including the pipes, including the faucets and everything you want to use for it. We will just follow now the line of this rain water, how it comes into our house, and you can see how we use it. So what you see here... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
So, we see from back there that the pipe that comes from the water tank, from the rainwater tank, comes in here and then goes into this little pump. And this little pump has a pressure tank in here so that the pressure is always there. Because what we... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Hi, this is Phil Coonrod on behalf of Expert Village. Today we're going to talk about how to beat Call of Duty 4 Modern Warfare. Call of Duty 4 Modern Warfare is a registered trademark of Activision. Accompanying which I have no affiliation. Okay we're... Read More »
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 11:03 AM
recirculating hot water problem cliff Plumbing 3 08-20-2007 01:40 PM
water pressure problem rgmetro Plumbing 6 04-09-2007 05:57 PM
Water Delivery Problem amadis Appliances 6 12-21-2006 12:22 AM
Drywall, Mold Problem due to Leaked Water june03 Building & Construction 2 10-31-2006 09:24 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
