Hot Water Quits When Cold Water Turned On - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-19-2011, 05:19 PM   #1
hot water quits when cold water turned on
Does anyone have any idea why the hot water quits whenever the cold water is turned on to make the water warmer. Then we only get cold water.
pudder is offline   Reply With Quote
Old 03-19-2011, 08:35 PM   #2
Rewards Points: 1,532
In a shower? If so, temperature balancing valving likely needs cleaning/replacement.
bob22 is online now   Reply With Quote
Old 03-20-2011, 01:27 PM   #3
the hot water quits when cold water turned on throughout the house not just the shower. Help!
Old 03-20-2011, 04:52 PM   #4
Check the dip tube on the hot side of your HWT.
VIPlumber is offline   Reply With Quote
Old 03-21-2011, 08:52 AM   #5
Hot water quits when cold water turned on throughout the house. We have a brand new whirpool electric hwt so I don't think it is the dip stick. Any other suggestions?
Old 03-21-2011, 02:15 PM   #6
Homerepairguy's Avatar
Rewards Points: 990
Wonder if it's the anti-scald valve (if you have one) on your water heater? The anti-scald valve (also called a tempering valve or mixing valve) will probably look like a H connection above your water heater. It connects the cold water line to the hot water line and allows cold water into the hot water line if the hot water temperature is too high. If you have one, maybe try this:
1. If you have insulation on the pipes into and out of your water heater, find a way to feel both pipes a before and after the anti-scald valve. Further away from the tank the better.
2. Have someone turn on a hot water faucet. The hot water pipe should get hotter.
3. Have someone turn on a cold water faucet which stops the hot water flow. -- Does the hot water pipe out from your heater get cooler? If so, maybe your anti-scald valve isn't working properly.
Link to anti-scald valves:
http://www.inspectapedia.com/heat/MixingValves.htm
HRG
Homerepairguy is offline   Reply With Quote
Old 03-21-2011, 03:52 PM   #7
Thanks, we'll check that. Appreciate everyone's input.
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
can't shut off cold water from main disconnect DanBress Plumbing 3 01-06-2008 07:20 PM
