#1 |
Hot water problems
I rent a small garage apartment. When I turn on the hot water, sometimes it's hot -- but most of the time it is usually just warm enough to take a shower. Most of the time, by the end of the shower, the water turns cold (and I take quick showers!). I can turn the water on 30 minutes later, and it will be extremely hot. An hour later, it will be just warm again. There is no rhyme or reason to it. I know the hot water heater has been replaced, but this problem has happened both before and after the heater was replaced. Any ideas?
#2 |
Hot water problems
My first guess would be the anti scald valve inside the shower valve as some trash in it causing it to stick.
Have you checked the other faucets to check there temperture when that shower is messing up to see if there hot. |
| Display Modes | |
| Hot Water Flow Problems | bcdad | Plumbing | 3 | 12-11-2012 04:42 PM |
| My hot water recirculation system is a disaster | Michael Neill | Plumbing | 9 | 11-05-2010 12:31 PM |
| No water draining into sump pit | aci4369 | Plumbing | 2 | 08-18-2009 01:17 PM |
| Water Heater Problems | martyshel | Electrical | 4 | 01-24-2009 01:07 AM |
| Testing 12 year old hot water expansion tank? | DJfixer | Plumbing | 2 | 01-01-2009 09:09 AM |
