Old 07-02-2009, 02:54 PM   #1
Default Hot water problem
Hi,
I am experiencing a loss of hot water fairly regularly these days. I have a hot water boiler which feeds three circuits of hot water baseboard in the house and heats hot water that is stored in a tank in the basement. Recently I have noticed that we often lose the hot water. When I turn the thermostat up enough to turn the boiler on for the baseboard heat, we will once again have hot water for a while. However, since the weather is warm enough now that we don't have the heat on normally, we keep running out of hot water. Is this a thermostat problem? Is there a thermostat in the hot water tank that should be calling for the boiler to kick on when it gets cool enough that is probably not working or could it be something else?
Thanks for your time,
GES145
ges145 is offline   Reply With Quote
Old 07-04-2009, 08:49 PM   #2
Default boiler are not to trifled with.
i'm very serious here. this one time i will not tell you anything, except to call a boiler company or a plumber that works on boilers. i am a master plumber and have been around boilers since i was 4 years old. for your safety, please call someone. this can be remedied. breid
breid is offline   Reply With Quote
Old 07-04-2009, 09:07 PM   #3
Yoyizit's Avatar
This link is in line with what breid said
http://en.wikipedia.org/wiki/Boiler
This one gives some basic hints
http://www.hvacoracle.com/cgi-bin/pu...=303&s=heating
and
http://www.youtube.com/watch?v=1WoA2mxtSHU
"What can't be seen in video is boiler went thru wall behind maint man into the plant and boiler door went thru far wall into parking lot. The maint man died later at hospital."
and
http://www.youtube.com/watch?v=FUeCk...eature=related
Old 07-05-2009, 07:32 PM   #4
Thank you both. I'll call a plumber!
More On This Topic
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Hi, I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're gonna do some work for you today on Expert Village. Now we're gonna repair a broken bolt in a 63 Cadillac water passage bypass to the housing. The '63... Read More »
Most people think about their water heater only when it fails. It's one of those things you couldn't live without, but as long as it does its job, you ignore it. And when it breaks down, you have no idea what to do. You can replace that old water heater... Read More »
How to Heat Gecko Habitats
How to Heat Gecko Habitats by Expert Village
Hi, I'm Johan Svahnström on behalf of Expert Village. It's really important to find one or two good heat sources for your leopard gecko. Now, don't keep him outside in the warm climate. It might get too humid, insects might come in there, and other... Read More »
Magic Chef HVAC water problem jfriday HVAC 2 08-15-2009 11:01 PM
Water on my new installed tiles....problem? yummy mummy Tiling, ceramics, marble 6 06-25-2009 10:43 PM
Hot Water Problem bob6831 HVAC 0 05-03-2009 01:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 10:36 PM
recirculating hot water problem cliff Plumbing 3 08-20-2007 01:40 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
