Hot Water Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2009, 11:30 AM   #1
Hot Water Problem
Hi,
New to the forum.
Couple of questions...........on my Weil-McLain Gold Oil Burner
1) I have noticed that my shower water requires a bigger turn of the faucet to get hot water. ......... what is the control on the boiler to turn the water temp up? and.......... why would it change like that? (boiler was serviced in December).
2) My boiler has been discharging (through outlet drain pipe) quite a bit of water ......... maybe about 1 gallon every couple of months........ is this normal? ..... if not, then what would cause that?
3) A couple of years back, my heat registers were making noise.... believe was told by our oil company (who also yearly service our system), that would cost about $300 to remove air from the pipes? Is this something that need professional to do? Also.. have read that coils may need to be cleaned????
Thanks for the help.
Bob
bob6831 is offline   Reply With Quote
Old 05-03-2009, 11:32 AM   #2
sorry, posted to wrong bucket!
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
recirculating hot water problem cliff Plumbing 3 08-20-2007 11:40 AM
