Hot Water Problem? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2014, 11:49 PM   #1
Rewards Points: 258
Hot water problem?
Okay so my wife just asked about the cost of a tankless hot water heater... In other words after a shower not a long one either she was out of hot water. So I went and took a look at the hot water heater and noticed that there was water on the top. The first pic looks like paint bubbling but that is water drops. And the it looks corroded around the other fittings. The heater is heating water currently So do I need a new water heater?
Hot water problem?-image-2159627614.jpg   Hot water problem?-image-713431827.jpg
redman88 is offline   Reply With Quote
Old 01-18-2014, 05:54 AM   #2
Rewards Points: 320
It looks in pretty rough shape. Can you post some better pics of it. Thanks. Could have issues, like cracked or deteriorated dip tube, etc. How old is it? Ever been serviced? Make and model?
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
oh'mike (01-18-2014)
Old 01-18-2014, 06:35 AM   #3
Rewards Points: 258
The only date I could find on it was on the energy efficiency yellow tag say the data is based on 1998 data. And I don't know when It was serviced last
Old 01-18-2014, 06:39 AM   #4
DIY staff
Rewards Points: 7,174
Tankless heaters have improved a lot in recent years---however,the instalation costs are high---new vents need to be run---water and gas lines must be reconfigured--
So check on the install cost---if you will be doing this yourself---you will have a lot of questions---consider Navien---high end units but dependable ---
Old 01-18-2014, 09:24 AM   #5
Rewards Points: 4,796
There are electric tankless heaters, but there was only 1 brand I found when I looked into it that might be "serious" enough, but even then I wouldn't trust electric over gas to heat enough.
I have a Noritz and love it. There used to be federal tax incentives to install one - I believe I got a $1,200 tax credit. Without that, there will be initial pain for the installation cost. But you will never run out of hot water, you will never need to do maintenance on your tank, and there is no tank to wear out.
jeffnc is offline   Reply With Quote
Old 01-18-2014, 10:04 AM   #6
Rewards Points: 320
I agree with you, at over 16 years old, it would be wise to start looking for another one soon.
You can also google tankless vs tank so you are better informed to make a decision. As mentioned there are a lot of incentives from government and utility companies. You'll have to do the math and see which is right for you. Myself, I still like the old tank for now.
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
Hot water problem ges145 Plumbing 3 07-05-2009 05:32 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
hot water recirculating/sediment confusing problem rcatty Plumbing 1 01-06-2008 03:51 PM
