Hot Water Pressure In The Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2007, 08:26 PM   #1
Hot water pressure in the shower
Suddenly our hot water pressure in our master bath shower has gone way down. The pressure is fine when the cold water is running. The pressure is fine in the sinks for both hot and cold in the same bath. If the valve is turned to the hot the pressure drops then??? Any help would be great.
Randy Stuempfig is offline   Reply With Quote
Old 12-09-2007, 08:29 PM   #2
There's probably something jamming up the mixing valve. Shut off the supplies to the shower, remove the cartridge, give it a good shake, and clean out anything that doesn't belong.
I think that's how I'd start. Any tips from the pros?
NateHanson is offline   Reply With Quote
Old 12-09-2007, 08:53 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 332
Ayuh,......... It's Got to be the Faucet......
Bondo is online now   Reply With Quote
Old 12-09-2007, 09:36 PM   #4
While you have the cartridge out is a good time to slowly open the hot supply and make sure you have a good flow. If there is any more trash in the line this will flush it out.
scrapiron is offline   Reply With Quote
Old 12-09-2007, 11:20 PM   #5
Master Plumber
Rewards Points: 150
You haven't said what brand of faucet you are dealing with. It really matters. Some brands of washer less systems have a pressure balanced cartridge that will fail (moen posi-temp for example) and then no hot water. What is the brand...is it compression or washer less?
jpplumber is offline   Reply With Quote
Old 01-02-2008, 05:44 PM   #6
Its a Price Pfister with just a one lever system. The cartridge I think is compression, but I just replaced it and it still doesn't work. Not sure where to go next.....
Old 01-02-2008, 06:03 PM   #7
yam
I've got the same problem with my shower valve (also a price-pfister single lever type). Please keep this thread updated if you discover the cause of the problem.
I wonder if this indicates a systemic quality problem with Price-Pfister hardware?
yam is offline   Reply With Quote
Old 01-02-2008, 06:06 PM   #8
I sure will and if you figure out anything let me know also...I'm so frustrated with this.
Old 01-02-2008, 08:46 PM   #9
Master Plumber
Rewards Points: 150
You could have dip tube from the water heater plugging up the valve (in back of the cartridge) if it is only the hot side not working...btw, if it is single lever it is washer less on price pfister.
Old 01-02-2008, 08:53 PM   #10
Reply....Is there a easy way to clean out the dip tube?? All I see behind the cartridge is the copper piping. One hole for the hot, one for the cold. The cartridge does have two washers on the back. One for the hot and one for the cold.
Old 01-02-2008, 08:59 PM   #11
Master Plumber
Rewards Points: 150
if it looks all clear then you need to see if you have pressure through the hot side without the cartridge and without any isolation valves you will probably need to just ease the water on from the main and visually see if it comes out the hot side and maybe put your finger over where the cold water comes out and feel the difference....my guess is there is something stuck in there
Old 01-02-2008, 09:03 PM   #12
Master Plumber
Rewards Points: 150
and it may not come out from where the cartridge is so you will end up cutting the valve out and installing 1/2" ball valves on the hot and cold supply lines and testing from there without the shower valve involved
Old 01-02-2008, 09:44 PM   #13
Sounds like I need another plumber. I see your in Texas. Anywhere near Flower Mound?? It really seems like you know what your talking about. Thanks for your help and your ideas. I guess the best way to do this is to work backwards to see what it blocking it.
Old 01-02-2008, 10:23 PM   #14
Master Plumber
Rewards Points: 150
Sorry, I was busy on another thread...I sent you a private message as I don't want them to think I am soliciting business even though you asked. Let me know if you get it or not, check up by your name in the top right corner on the plumbing main page.
Old 01-02-2008, 11:00 PM   #15
I got your message and I'll probably call soon. I couldn't reply because I don't have enough threads or something.....Thanks.
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 03:32 PM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 07:55 PM
New Water Heater, worse pressure Repoman75 Plumbing 6 04-16-2005 12:30 AM
