Hot Water Pressure Problem (unusual Situation) - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2011, 12:38 AM   #1
Hot water pressure problem (unusual situation)
Hello,
Mine is 5Y old house with public water supply in California, 50G gas water heater tank and copper piping. Cold water pressure is very good, but hot water pressure is very low at all points. Flushed the hot water tank, still problem remains.
Did some trial and error method and found a strange situation. Normally, hot water pressure is very low, but hot water pressure increases considerably in first tap, when second tap is on with both hot and cold water mixed. Even observed that hot water in bathrooms increases when cold water is on in the kitchen.
Can some one explain the cause of the problem.
Thanks in advance.
tanna is offline   Reply With Quote
Old 09-03-2011, 06:48 AM   #2
DIY staff
Rewards Points: 7,174
What kind of shut off valve protects the heater---gate valve or ball valve?
Old 09-03-2011, 08:17 AM   #3
Rewards Points: 1,514
Originally Posted by tanna View Post
Hello,
Did some trial and error method and found a strange situation. Normally, hot water pressure is very low, but hot water pressure increases considerably in first tap, when second tap is on with both hot and cold water mixed. Even observed that hot water in bathrooms increases when cold water is on in the kitchen. e.
Probably some constriction in the hot water piping prior to the tap where you mixed cold and hot. Or maybe in the cold inlet to the water heater.
You are getting improved pressure because the cold water from the hot and cold mixed fixture is backfeeding to the hot water lines and adding to the pressure.
Could be sediment hung up in the piping, just before the cold water inlet shutoff to the water heater is a likely location.
Try this. Turn off all the upstairs faucets but leave the main house water valve and the water heater cold inlet valve open. Open the water heater drain valve. Is this slow also?
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 02:59 PM
Well Water System Problem browning Electrical 6 09-12-2010 06:14 PM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
water pressure problem krw1957 Plumbing 1 12-10-2007 10:34 PM
