Old 12-24-2009, 09:50 PM   #1
hot water pressure much lower than cold water pressure
In one of my bathrooms the hot water pressure is very low compared to the cold water pressure. It takes forever to fill the tub with hot water. The bathroom is located at the same point the main water supply comes in the house. So, the main water line goes to the shower before it goes to the water heater. I'm thinking this is the cause of the low hot water pressure for that shower.
Can someone tell me what the cause is? TIA
lockingpin is offline   Reply With Quote
Old 12-25-2009, 12:08 AM   #2
it has to go to water heater before it goes to shower, or you wont have hot water. should be adjustment at water heater....or you can adjust at the street thru your main shutoff....
JGibbsRemodel is offline   Reply With Quote
Old 12-25-2009, 12:26 AM   #3
Do sinks have the same issue, or just the tub in this bathroom. If just the tub, them maybe something with the fauset there.
Old 12-25-2009, 02:17 AM   #4
very true...
Old 12-26-2009, 05:19 PM   #5
What I meant to say is the first branch off the main goes to the shower. Then about 15 feet later it goes to the hot water heater. Everything else that needs water (sink, toilet, other bathroom, kitchen) receives the cold water after it goes through the water heater.
Old 12-26-2009, 05:23 PM   #6
The shower actually comes before the water heater. Look at the attachment in my last post. So, they decided to just hook up the cold water to the shower before the main supply hits the water heater. I think this is the cause. I don't want start changing out the pipe if this is not a big deal though. What do you think? TIA
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 04:01 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 10:23 AM
