Hot Water Pressure Is Low - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-09-2013, 02:29 AM   #31
krey's Avatar
And FYI obviously my grandpa knows more than I do about plumbing I tried emptying my water heater first to avoid any high cost plumbers fee! So that's why grandpa!
krey is offline   Reply With Quote
Old 02-09-2013, 02:31 AM   #32
krey's Avatar
Under kitchen sink
Hot Water Pressure is Low-image-2808800662.jpg   Hot Water Pressure is Low-image-1277935931.jpg   Hot Water Pressure is Low-image-3748704541.jpg
Old 02-09-2013, 02:32 AM   #33
krey's Avatar
Water heater and under bathroom sink
Old 02-09-2013, 09:49 AM   #34
Rewards Points: 77
Is the water pressure always slow or fast for a second right when you turn it on and then slows down? If it's fast right at first then there is buildup in the piping somewhere - - valves etc like the others mentioned.
How old is the house? When you flush the tank, does it seem to have a lot of pressure or is it also slow?
dengle is offline   Reply With Quote
Old 02-09-2013, 11:46 AM   #35
krey's Avatar
Yes it's fast then slows down...not sure how old but I know it doesn't have galvanized pipes....does that help at all?
Old 02-09-2013, 11:48 AM   #36
krey's Avatar
Just wondering..how can all my valves be clogged at one time though? Valves are under the sink right?
Old 02-09-2013, 12:12 PM   #37
Roofmaster
Rewards Points: 2,172
From the looks of those valves, they have been leaking for some time. From the amount of efflorescence on the outside, the inside must be nearly shut down. All of them should be replaced as soon as possible. Sounds like you have a pinhole of flow left.
By the way, Thanks Joe. You are correct, Globe Valve.
Old 02-09-2013, 12:41 PM   #38
krey's Avatar
Thanks so much I've got a plumber coming out Monday!!! Thank you guys so much! I will keep y'all posted!!!! I've learned a lot about plumbing!!!
Old 02-09-2013, 12:42 PM   #39
krey's Avatar
Oh and yes when I flushed the tank it was real good pressure!!!!
Old 02-09-2013, 12:42 PM   #40
krey's Avatar
Sure wish y'all lived here so y'all could be my handyman!
Tags
hot water pressure
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 07:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 07:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
