Hot Water Pressure Is Low - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2013, 12:55 PM   #16
Rewards Points: 6,652
If hard water, it can close up gate valves, to the point that there is little flow, so you have no choice, but to replace them with ball valves. Easiest ones to use for replacements, are the shark bites. Compression type valves, you need to not over tighten the nut, to cause the Copper piping to collapse.
If an old house that still has galvanized Potable water piping, those pipes rust from the inside out, and tend to also close up more easily than Copper, from hard water deposits.
Check with your local University, farm bureau, or even Culligan Water can give you a report of the hardness of your water. Your utility that you get water from, might also be able to tell you the hardness of your water, if you contact them, and ask for a report, if they do not send one out yearly, or have available on their website.
Old 02-08-2013, 01:05 PM   #17
krey's Avatar
I will show my grandpa this...as all of this plumbing talk is seriously like I'm reading foreign language. :-( I just hope it's not something MAJOR.
krey is offline   Reply With Quote
Old 02-08-2013, 03:51 PM   #18
krey's Avatar
Old 02-08-2013, 04:28 PM   #19
krey's Avatar
The flushing did not help.....turning off valves did not help...cleaning fixture screens did not help....
Old 02-08-2013, 05:57 PM   #20
Next step is replacing the valves.
Old 02-08-2013, 06:03 PM   #21
krey's Avatar
Out of curiosity how will that help if I turned them on and off and it didn't work? Would new valves solve this problem? I hate PLUMBING!!!!
Old 02-08-2013, 06:42 PM   #22
If your old valves are gate valves, as already stated, they can be clogged, and causing the low flow. Ball Valves do not have the symptomatic problems, that gate valves have, when open, so no way for crud to catch on a lip, like gate valves are constructed inside.
Old 02-08-2013, 06:49 PM   #23
krey's Avatar
Should I take a picture of my valves for you? I don't have galvanized piping by the way. I don't know if that's important or not...I just hope it's not under the slab.
Old 02-08-2013, 07:35 PM   #24
Roofmaster
Rewards Points: 2,172
How about calling a real plumber? Nothing against Grandpa, of course.
Old 02-08-2013, 07:39 PM   #25
Probably is not a big deal. I would not worry, you will adjust to cold showers.LoL. I second the valve problem. Please take a picture or two of the copper pipes on the top of the water heater. Take a close up of any valve looking thing with a handle you can turn. What I am thinking is you and your Grand Father can shut the water off and take the handle part off of the valve and maybe clean the inside of the valve to remove the junk inside the pipe.
paintdrying is offline   Reply With Quote
Old 02-08-2013, 09:29 PM   #26
This is a Gate Valve
This is a Ball Valve
Old 02-08-2013, 10:58 PM   #27
Roofmaster
What you are showing is not a Gate Valve, Greg. It is what used to be called a ball valve.
In a Gate Valve A wedged shaped Gate drops straight down like the gate of a castle. It is a straight through valve like a modern ball valve.
Old 02-09-2013, 12:11 AM   #28
Rewards Points: 12,882
Nope, both wrong that picture is of a globe valve.
A gate looks like this.
http://www.bing.com/images/search?q=...lectedIndex=55
jagans (02-09-2013)
Old 02-09-2013, 12:17 AM   #29
Does it really matter. At this point it is semantics, and the two posted that I linked, are the common ones found in the home. Go to any big box, and look on the labels, what does it state for the two items that match what I posted cut-aways of?
Again, Gate valve http://www.lowes.com/Search=gate+val...Ntt=gate+valve
Ball Valve http://www.lowes.com/Search=ball+val...Ntt=ball+valve
Any more questions class?
Old 02-09-2013, 03:25 AM   #30
krey's Avatar
I'm about to post a close up picture of my water heater and pipes under my sink hold on just a bit. Again I just hope it's not something under the slab...have anxiety about this...
Tags
hot water pressure
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 08:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 08:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
