Hot Water Pressure Drop Only After Tap Turned On-intermitent - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2011, 06:31 AM   #1
Hot water pressure drop only after tap turned on-intermitent
Hot water flow and pressure drop off when any tap is turned on.Cold is fine.Happens after the system has not been used for a few hours. If you leave the tap running long enough, can hear a very loud bang noise and pressure is fine. Almost like a valve is sticking. After this happens, theflow/pressure will be good for several days. Water heater is a Superflue powervent. Would it be a flow valve in the heater.
rickdanard is offline   Reply With Quote
Old 05-07-2011, 07:53 AM   #2
Plumb or Die!
Do you have a check valve in the hot water piping?
plumber666 is offline   Reply With Quote
Old 07-11-2011, 06:38 PM   #3
I have not sen one, but some of the plumbing is concealed. I think there could be a back check in the hot water heater. It might be sticking. I may have to pull some panels down to look for additional valves.
Old 07-11-2011, 06:42 PM   #4
what is the thing called that stores water under pressure for low water pressure? oregongirl23 Plumbing 26 05-31-2017 09:50 AM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water pressure and temperature billvasko Plumbing 9 06-02-2008 09:23 AM
