Old 09-21-2010, 01:27 PM   #1
hot water pressure
i emptied my hot water tank and then refilled it , but the hot water pressure is now low, when i turn a hot water tap on , it flows slowly then spits if its a airlock but then stops ?
chrisroberts is offline   Reply With Quote
Old 09-21-2010, 01:39 PM   #2
hot water pressure
Are you sure that you opened all of your valves?
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 05:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 08:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
