Hot Water Pressure? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-11-2009, 10:04 AM   #1
hot water pressure?
in my master bathroom the cold water pressure is great but my hot water pressure isnt good. both pipes under the house go from3/4" to 1/2" in the same spot. why dont i get good hot water pressure?
mayesj47 is offline   Reply With Quote
Old 12-11-2009, 12:02 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If cold has higher pressure than hot, i'd say its most likely some kind of blockage somewhere in that area. Could be sediment blown through from the water heater?
Is it only one fixture in the master, or all fixtures?
Journeyman Plumber
Old 12-11-2009, 01:10 PM   #3
both fixtures. the hot water was running to the toilet but i switched that. under the house on both lines i put a shutoff valves. could it be in the valves?
Old 12-11-2009, 01:54 PM   #4
Doing it myself
Alan's Avatar
Could be if they are not fullway valves, and they are choking the flow down to smaller than 1/2"
Did you only notice the change after you fixed the toilet?
Journeyman Plumber
Old 12-11-2009, 02:22 PM   #5
both valves are the same. just no hot water pressure. i havent turned the water back on since ive fixed the toilet. maybe the toilet was the problem? can glue get in the valve and clog it up?
Questions about water pressure regulation.. MrSimmonsSr Plumbing 21 05-13-2017 07:08 PM
Decreased water pressure in home Gordon07 Plumbing 3 12-03-2009 11:44 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
