Old 03-06-2012, 11:51 AM   #1
hot water pressure is 57% less than cold on new water heater
new replacement water heater has less pressure, could I have a faulty water heater? I checked GPM at 3/4 discharge hot 6.16 & cold 10.68 at the tub faucet hot 2.8 cold 4.8. After the new install, if any hot water faucet is turned on the shower goes cold. Did not have this issue with the original water heater, is this a bad unit?
wdgates is offline   Reply With Quote
Old 03-06-2012, 11:55 AM   #2
Hmm, very little info. no pictures.
What other plumbing did they do when installing it?
Where are you checking the flow.
100% sure the valves are fully open that someone had to shut off to change the heater.
What type valves are they?
Why was the heater changed?
Old 03-06-2012, 12:22 PM   #3
I replaced a bradford white direct vent (22yrs installed) with a Powerflex direct vent. I measured GPM from two 3/4 copper pipes that was used to feed a temp kitchen down the basement and also in the bathroom tub faucet. I did three test bucket fills and the avg has been posted for the hot & cold at each location. No other work was done.
Last edited by wdgates; 03-06-2012 at 12:30 PM. Reason: brand change from american standard to powerflex
Old 03-06-2012, 12:27 PM   #4
More likly there's trash in the shower valve and the anti scald valve inside the control.
Very common to happen after major plumbing work.
Old 03-06-2012, 12:35 PM   #5
I'm showing the same % reduction of pressure straight out of the 3/4 pipe as the tub faucet. Should the hot & cold have the same pressure?
Old 03-06-2012, 07:41 PM   #6
did the shut off valve to water heater get damaged by shuting off??
Old 03-06-2012, 07:46 PM   #7
If it's an old style gate or globe valve and not a ball valve sometimes the shafts inside can wring off inside the valve from being stuck from have not been moved for a ling time.
The handle will still turn but the inside part does not move.
One sign can be the handle turns and turns and never comes up againt a stop.
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
New Water Heater, worse pressure Repoman75 Plumbing 6 04-16-2005 12:30 AM
