Hot Water Pressure? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-02-2009, 10:03 PM   #1
hot water pressure?
Hi, I turned my water off earlier today to change a broken shutoff valve under my bathroom sink. Now that I have turned it back on, however, I am getting low hot water pressure in my downstairs kitchen, and no hot water pressure upstairs in the shower (I haven't hooked the new sink up upstairs yet, though, so I don't know how the bathroom sinks pressure is). Any help please?
daresofthenew is offline   Reply With Quote
Old 06-02-2009, 10:19 PM   #2
I'm sorry, I should say that the problem is that when I turn the hot water on in the shower nothing comes out, not that there is no hot water pressure.
Old 06-03-2009, 09:11 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
Sounds like debris from the heater tank flushed into the lines and has probably clogged the aerator on the kitchen sink and the showerhead. Remove them both and then try the hot water pressure. If that was the problem, that should resolve it.
To clean the aerator and showerhead, you may want to soak them in vinegar overnight to dissolve any mineral buildup in them and then rinse and clean them out.
Whenever turning off water to work on plumbing, it is best to open tub faucets first (no spout aerator to clog) when turning the water back on. Let the water run until all air and possible debris are flushed out of the lines.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-03-2009, 04:26 PM   #4
Thanks a lot man. I'm gonna try that!
Questions about water pressure regulation.. MrSimmonsSr Plumbing 20 11-30-2012 09:43 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Water pressure? What water pressure? mnp13 Plumbing 9 05-03-2007 02:32 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-22-2006 11:42 PM
