Old 12-31-2012, 12:04 AM   #1
Hot water pressure
Our little bathroom remodel was suppose to be somewhat easy, so we thought. After day 3 of removing old plaster walls it was time to remove the old sink. Well the original owner/ contractor did not install shut off valves. After hunting the water lines down because there are several lines that dead end. We disconnect the old lines, install the new shut offs and replace the galvanized pipe that crumbled upon breaking the line free, hot water union, elbow and nipple. Now that everything seems to be back in order, we open all lines to turn the water back on. Cold water pressure all good, hot water not good.
To make it even more confusing, like I need anything more, the hot water works in the basement sink with good amount of pressure but not the kitchen or 1 of the bathrooms. (We haven't completed the new water lines in 2nd bathroom being remodeled yet.) The confusing part is that basement sink and the bathroom are connected to the same line. Only difference is basement lines go down and bathroom goes up. The kitchen is piped with copper pipe. Now both of these hot water line connect at a tee that comes off the hot water heater.
Any suggestions on how to get the pressure back? Or is it time to call the plumber? My husband has reached his breaking point; which usually means duct tape.
Thanks!
ckowal is offline   Reply With Quote
Old 12-31-2012, 12:41 AM   #2
Plumber & Gasfitter
Hot water pressure
The insides of old water lines get caked with "gunk" for lack of a better word, and often you drain your system the gunk will settle and fall down the lines and form a more solid build up. When you turn the water back on, the rushing water will push the gunk through the lines until either it comes out somewhere, or it clogs, most often in a fixture. (although i have seen it plug up an entire 1/2" copper 90)
If someone is somewhat handy:
1) buy a 3/8" braided supply tube or a 3/8" braided dishwasher connector (same thing as supply tube but about 5' long and bit more money)
2) and have them shut off the water at each of the offending fixtures.
3) Disconnect the water supply tube AT the shut-off and attach the recently purchased supply hose.
4) Put other end of the tube in a bucket, or in the fixture itself, and turn the water back on and see if you get any pressure.
If you do, then you have a clog in the fixture itself... probably gonna want to call a plumber.
or
If you don't, then the clog is most likely in your water distribution system.
So at that point you could:
1) shut off the hot water at the offending fixture
2) shut the water down at your HWT
3) open the drain port at the bottom of the tank (might need a hose)
4) disconnect the cold supply at the offending fixture and use your braided supply tube to connect both the hot and cold shut offs
5) open the fixture's hot shut-off... nothing should happen since the hot water was shut off @ the tank
6) open the fixture's cold shut-off and hopefully the cold water pressure will be enough to fire the blockage back down the hot line and out the thru the drain port @ the tank.
If that doesn't work, call a plumber.
joeplumber85 is offline   Reply With Quote
Hot water pressure low (pictures) bluefoxicy Plumbing 4 12-11-2012 08:45 PM
Low water pressure (hot water only) - temp fix when I shut off water supply to tank skilletrx Plumbing 5 11-15-2012 08:37 AM
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
