Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2012, 07:11 PM   #1
Hot water pressure
I live in a mobile home and had a water leak from hot water tank drain it and replaced the pipe. now in the tub there is verylittle hot water pressure. took the nozzle off the faucet still the same. I think this is also the tub is close to the tank except for the shower. All other faucets work fine
dakota11 is offline   Reply With Quote
Old 02-05-2012, 07:19 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Could have some junk in the hot water faucet stem
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-05-2012, 07:22 PM   #3
Rewards Points: 13,456
Agreed, or the anti scald is trashed up inside the valve.
Old 02-05-2012, 07:53 PM   #4
Since this is the cheap plastic type faucet might as well get a new faucet
Old 02-05-2012, 07:58 PM   #5
Rewards Points: 560
I would either take it a part to see if it is clogged first or replace it all
together
Old 02-05-2012, 08:35 PM   #6
how
Rewards Points: 1,104
In the future, with any plumbing pipe repairs, direct the water that first goes through your repairs to an outlet without a restricter or drain screen.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
ben's plumbing (02-05-2012)
Check valve gimaarob Plumbing 13 10-27-2011 10:13 PM
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
