Hot Water Pressure - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-27-2011, 04:29 PM   #1
hot water pressure
in the kitchen sink, cold water pressure is GREAT. Hot water pressure is almost nonexistent How can I fix this?
Annie M is offline   Reply With Quote
Old 07-27-2011, 05:18 PM   #2
biggles's Avatar
is it the same on the other hot water sides in the bathroom if no shut the valve under the sink and check the flow out of it blockage could be there.if the same all around might have mineral build up on the out pipe at the top of the heater ..like colesteral in a vain narrows the opening and the pressure drops going out.
Poor Hot Water Pressure After HW Heater Flush linuxrunner Plumbing 4 04-07-2011 07:24 PM
hot water pressure much lower than cold water pressure lockingpin Plumbing 5 12-26-2009 04:23 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Low water pressure upstairs but gauge reads 100psi? rivers72 Plumbing 7 11-15-2008 07:55 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
