Old 07-01-2009, 02:26 AM   #1
Default Hot Water Plumbing Problems
Hey there.
So we have an old home (1902) that is 3 stories.
We currently have a tenant in our ground floor apartment. She just informed me that she is unable to get the hot water to come out of the bathroom sink tap.
She could let it run and run and it will not get hot at the sink tap.
Her kitchen sink tap works fine.
Our kitchen sink tap works fine.
Our 3rd floor bathroom sink gets hot pretty quickly but
our 2nd floor bathroom sink tap has the same problem that out tenant does...
Our 2nd floor bathroom sink hot water has NEVER gotten hot (unless I take a shower in there beforehand) and we've just learned to live with it, since our primary bathroom is on the 3rd floor...
Anyway, this is a new problem ( we think) for our ground floor bathroom sink as our previous two tenants never mentioned it.
We have a tank (blech) water heater 80 gal on the ground level of the house, so her bathroom is actually the closest to the source of hot water.
We can't figure this out.
Any ideas oh plumbing gifted folks out there? Thanks!
danielhudson is offline   Reply With Quote
Old 07-01-2009, 07:15 AM   #2
Master General ReEngineer
Ayuh,... Is it a single handled faucet,..?? If So,... Change the cartridge,... It's stuck on the Cold side...
Old 07-01-2009, 08:00 AM   #3
ccarlisle's Avatar
It sounds like a progressive problem...i.e. it seems to be getting worse as time goes by, either that or your tennant never mentioned it before. Seems to be a question of getting hot water to all the faucets continuously...It also seems to be happening at various locations - not just one fixture.
So my question is where are you? do you have hard water? is the 80 gall tank original? have you had the anode rod checked recently?
ccarlisle is offline   Reply With Quote
Old 07-01-2009, 12:07 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Another possible issue...do you have old obsolete galvanized supply pipes? Those build up internal scale over time until the line eventually plugs completely up. The only solution is to replace the lines.
Mike
Mike Swearingen is offline   Reply With Quote
More On This Topic
We are going to talk a little bit about how we are going to get water to our shower, our toilet, our new washing machine, and our sink. What I had to do was I had to find a place where I could pull cold water and also pull hot water and being that these... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. Eventually we are going to come in with water and electricity. The only kind the water that we need is for a sink we are not going to put any kind of bathroom or commodes or... Read More »
Today we are going to talk about adding a bathroom to a home that is up for sale. It currently has one bathroom. The homeowner is thinking that if he adds another bathroom it will improve the value of his house and make it more appealing for someone to... Read More »
Ok. Now, we're going to talk about how we ran cold water. Again, our cold water line was already existing here. So, I cut off the old pipe added a ninety. And, we've started running it along the wall here. And, then here we have a "T" that runs up and... Read More »
Very Low Hot Water Pressure. PAS1970 General Discussion 2 02-25-2009 05:01 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 11:31 PM
Replacing plumbing system kbsparky Plumbing 5 09-16-2008 11:41 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
Low Water Pressure Eagle2 Plumbing 5 05-29-2008 12:29 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
