Old 05-15-2009, 02:30 PM   #1
Unhappy hot water pipe under the cement leaking
Is there anyway to fix this leak without digging up the cement? Could I possibly go through the ceiling and back over to the connection that comes out of the wall where the pipes come out under the sink? I know I have a hot water leak because I can feel a hotspot on the tile and there is no other explaination for it. The water meter is also moving indicating a slow leak and the water bill has been higher than usual. Any suggestion or help would be appreciated.
befuuddled is offline   Reply With Quote
Old 05-15-2009, 09:42 PM   #2
wannabe
Take the shortest route.. The longer the route. The longet it will take for hot water to get there
kenmac is offline   Reply With Quote
Old 05-16-2009, 02:11 PM   #3
If your ceiling is below an attic you will take a chance of the pipes freezing depending on where you live. Also are you sure that that is the only thing on that line?
al's sewer is offline   Reply With Quote
Old 07-02-2009, 04:58 PM   #4
Location: I live in San Luis Obispo, have crews that service Thousand Oaks to San Francisco, Kern, & Fresno.
Default Repair of leaking pipes.
http://CURAFLO.COM Hello
My company is Central/Northern Ca Pipe Lining Inc.
We coat the inside of "potable" water pipes, i.e. galvenized, copper or steel, with NSF 61 Certified epoxy. It is made to last 50 years and will not rust, corrode or peel. After it is applied, water may be returned to service after five (5) hours. It will fix PINHOLE leaks.
We coat the entire structure i.e. homes, condominiums, hotels, motels, hospitals etc, as once the leaks start, they will continue throughout the entire structure.
It is usually 20-30% cheaper than repiping and we give a 10 year warranty on parts and labor.
If I may be of help, please call:
Stan 805 674-8381
stanate is offline   Reply With Quote
More On This Topic
Hi! This is Kathy with City of Santa Barbara Water Resources for expertvillage.com. We are back looking at the meter again and what we are doing is looking for a leak. This meter has a leak indicator and I am going to point it out. It's this black... Read More »
How to Remove a Shower Head
How to Remove a Shower Head by Expert Village
Hi, I'm Adolph Ramirez from Tampa, Florida and on behalf of Expert Village, today I'll show you how to clean a shower head. The first thing you need to do when you lose power from your shower head is to carefully remove any structures that you may have... Read More »
Hi this is Fernando we are here with Expert Village you installation of you water system around hard corners, bends, etc. and for the most parts most the angles are straight but here you could see when we where clearing the trench earlier that this is... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Hi! I'm Cathi Pare with the City of Santa Barbara Water Resources speaking to you today for expertvillage.com. We've already looked at the meter and we determined that there was water running through the meter so the next step is we want to isolate is it... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Sump pump discharge pipe: the standing water trap! Deck Plumbing 7 05-20-2009 01:53 AM
Hot water tank leaking from valve pipe bookingohio Plumbing 12 05-07-2009 11:43 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 09:22 PM
cement porch retaining water jerry1967 Building & Construction 1 11-12-2007 05:49 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
