Sarah:
No, your water heater has a "pressure and temperature relief valve" on it that opens if the thermostat malfunctions and the heater keeps heating the water well past it's set temperature. The P&T relief valve is the thing near the top of the heater with the pipe coming out of it that goes down close to the floor. Typically, that P&T relief valve will open at 150 psi or 200 deg. F, whichever comes first. Also, your water supply piping is typically at a pressure of 40 to 80 psi, and so the boiling point of the pressurized water in the piping would be higher than 212 deg. F.
Originally Posted by Sarah24
Today when I finished my shower and went to turn the hot water off it suddenly make a weird loud creaky noise. I think the pipe might have actually been moving behind the wall - at least that's what it sounded like. I tried to turn it on again to see what was going on, but it made that noise again and I stopped right away.
That MIGHT be water hammer, but that noise doesn't happen when you OPEN the hot water valve... water hammer only happens when you close a valve, and the faster the water is running and the faster you close the valve, the more magnificent the water hammer will be. That's because water is heavy and it has considerable momentum when it's flowing through a pipe. If you suddenly stop the flow of the water (by closing a valve), then the momentum of that water is transfered to the pipe, and the whole pipe lurches forward and back if it can. It's supposed to be anchored with clips every so often to prevent it from moving, but builder's don't always put those clips in as often as they should.
But, I kinda doubt it's got anything to do with water hammer because water hammer doesn't happen when you OPEN a valve, only when you close the valve.
What you're probably dealing with is just a loose washer on the hot cartridge in your shower valve. You see, when the screw holding a rubber washer in place is loose, then the water pressure in the piping can get behind the washer and slam it forward, and the water pressure in the piping can then slam it backward again so quickly that it can sound like anything from a cat squeeling to the Queen Mary's fog horn. This will ONLY happen when the faucet is just opening or just closing; it won't happen once the faucet is open more than just a bit because then the washer is further from the seat and can't stop the flow of water, and it's that rapid starting and stopping of the water flow that causes the noise and vibration.
(I suppose it could happen even when the faucet was wide open if the screw holding the washer in place was so loose it was about to fall out, but if this is the first time you've heard the noise, my bet is that the screw is just a little loose and not about to fall out.)
Now about an hour later I tried again, but the noise stopped.
Which also confirms to me that it's probably a loose washer. That loud noise requires that the washer move forward and backward rapidly, and it's the water pressure getting behind the washer that causes that. But, it doesn't always happen. Some times the water pressure doesn't move the washer forward at the time you're opening or closing the faucet, and the faucet behaves.
We've been having weird problems with the shower for awhile now. We sometimes get sudden bursts of water pressure in the shower.
I was the one who suggested scale build-up in your "Insane water pressure in shower" thread. Did you take a listen to that water heater while the shower is running to see if the heater is also making noises that coincide with those high pressure episodes?
So now I'm freaking out thinking the pipes about to explode. Also it might be relevant to mention that I live in a very cold state - it's about -2 degrees, so I'm not sure if that has anything to do with it, but I'd thought I'd mention it just in case. However, my pipes are fully winterized and I still leave the kitchen faucet drip just in case. So.... if anyone has idea what this could possibly be please leave a comment.
Temperature doesn't cause any problems at all unless the pipes freeze solid.
Try getting the hot water in the shower to make that noise again, and then while it's making that noise, gradually open the hot water more to see if the noise stops as the washer is moved further from the seat so that it can no longer cover the seat and stop the water flow. If the noise goes away as the hot faucet is opened, then you know the problem is a loose washer.
